Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    just give the starter a whack with a hammer. there is a coil inside it that usually gets a short in it. Giving it a whack or two usually fixes it. But if it happens again, you know what to do.
    www.youtube.com/ippielb
  2. #22
    can you help me by telling me where the relays are? i cant fine nothing under the hood?.... and ive tried hitting the starter then crawling out and tryna start it and didnt work.. but i guess ill try that again.. but knowing where the relays are would help thanks for the info
  3. #23
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    If you can positivly determine the clicking you hear is coming from the starter then you can be sure it is not your wiring to it. Double check the positive connections from battery to starter and if they are in good shape then your starter is at fault. Oh, and as Conlan pointed out, there is alot of current available on those wires so be careful and disconnect the negative terminal before you do so. Loud, large and bright sparks await the missplaced tool if you don't!
  4. #24
    yes im sure that the one click that i hear is from the starter because while i was under it it my brother pushed the button while i was under there and it is the starter, but i maybe be wrong but wouldnt hearing that click mean that the starter is getting power?
  5. #25
    Yup but it might not be getting enough power. Try out our fixes and see how it work.
  6. #26
    yea hitting the starter does nothing?.. just curious about where the relay is? and im bout to take the tire off to look a the connections because i cant from under the car, and looking from the bottom.. theres a like a small hole not sure if that should be there?
    i only see see one wire clearly and that the wire thats in the middle of the too big "bolts?" on the soloniod
  7. #27
    How big is it? Can you take a pic. The relay is in the under hood fuse box.
  8. #28
    i cant find a fuse box under the hood, and the hole its a small one and yea ill take pics tomorrow.. but i did what you said i shouldnt do but im still alive and jumped the starter but all that happend was clicks nothing so will that mean that the starter is deff bad and i need a new one? and the starter is the problem?
  9. #29
    Yah starter is likely dead.
  10. #30
    ok so to remove the starte i undeo the two blots that i can see from laying under the car? then guide it threw and undo the bolts thats on the soliniod
  1. Starting problem
    By dennis24 in forum General Chevy & GM Tech Questions
    Last Post: 05-22-2012, 10:18 PM
  2. '03 Silverado Intermittent Crank Problem
    By jaf in forum General Chevy & GM Tech Questions
    Last Post: 01-03-2010, 04:51 PM
  3. starting problem
    By ymh401 in forum General Chevy & GM Tech Questions
    Last Post: 12-10-2009, 04:19 PM
  4. starting problem
    By L0sts0ul in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 06-26-2009, 11:32 PM
  5. starting problem
    By ChevyPrincess in forum General Chevy & GM Tech Questions
    Last Post: 06-01-2009, 11:21 PM
