    Jun 2010
    Abingdon, MD
    Default How to Get Transmission to Temperature
    I have been driving my 2010 Silverado around trying to get the temperature to 160 to check the fluid level. No matter what with the outside temps in the 30's, I only get to 140. Any ideas?
    Kent
    You probably have a towing package, which includes a transmission oil cooler. The air temp may be too cold to get the fluid any warmer.
    Try to cover the front of the radiator (grill) to slow the flow of cold air.
    It doesn't have to be hot to check it, pull the stick when it's cold. If it shows quart overfull then it's perfect, I check mine all the time like this.
  1. Air temperature sensor
    By PRED888OR in forum Performance & Fuel
    Last Post: 05-02-2011, 02:02 PM
  2. What temperature does your engine run at?
    By Z28Johnny in forum GM Powertrain Tech
    Last Post: 11-15-2010, 06:33 PM
  3. Transmission Temperature
    By at4rxj in forum GM Powertrain Tech
    Last Post: 06-15-2010, 01:18 PM
  4. Temperature
    By Stealth in forum The Coffee Shop
    Last Post: 04-07-2010, 10:15 AM
  5. Transmission Temperature
    By cigar_stub in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-02-2010, 08:13 PM
