Results 1 to 2 of 2
    Default 2001 Suburban frront driver side window not moving up or down
    Went to a drive through this am and came to find out my driver side window will not go down. Anybody has a wiring diagram foe the power windows before I start taking down the door panel and switches.
    Thanks.
    1993 964
    1996 318TI
    Spent some time this morning and pulled the switch console on the driver side arm rest. I am getting 12 volts coming out of the switch but the motor is not turning. I think I will go ahead and buy the regulator/motor set before I open the door panel.
    Amazon has a $43 window regulator/motor set.
    I think I got lucky today. Before I attempted to pull the panel off, I tried it one last time and pressed the switch and the window started rolling down. I tried to roll it up and it did. I will try to lube the glass channels and call it a day.
    Do I still need to try and pull the door panel and lube the regulator?
    For future reference, here is the piniout of the driver side window switch plug. This is the plug in the middle of the sketch attached. If you put the +probe on the 12 VDC UP pin and the neg probe to ground, you should get 12 VDC whenever you press the UP window button. This will confirm the switch is sending power to the window motor.
    Hope this helps.
Name:	SWITCH CONSOLE.jpg
    1993 964
    1996 318TI
  1. Problem with Driver-Side Window
    By swhite64 in forum General Chevy & GM Tech Questions
    Last Post: 09-11-2012, 12:25 PM
  2. Rubbing noise when rolling down driver side window
    By eanderse in forum General Chevy & GM Tech Questions
    Last Post: 05-11-2011, 09:53 AM
  3. driver's side rear power window motor out
    By jmb275 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-21-2010, 11:36 PM
  4. Driver's Side Rear Window Gremlin's.
    By Allmostsmart in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-18-2009, 11:26 AM
  5. Driver Side Window Problem
    By ukrkoz in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-07-2007, 05:17 PM
