    Default Banks system on 6 liter gas
    Hi,
    I have a 2003 2500HD with the 6 liter gas engine.
    I need some information from anyone that might be using Banks system.
    My truck is rated for 10400 lbs. I purchased the truck last year to pull a travel trailer, but started looking at 5th wheels. The problem there is the weight. The lightest 5th wheel that we looked at came at just over 9000 lbs dry. This would the upper towing level for my truck. I could do it if I stayed in the mid west. But I want to be able to pull over the Rockies. In 2007 the 6 liter was upped in horse power and had a towing rate of around 12000 lbs. This would be enough for me.
    What I would like is information from someone that might be able to help with information on using the Banks Stinger Kit ( ram air inlet, exhaust, tuner). For the $$$ did the performance improve? What happened to mpg?
    Thanks for any help
    Tom
    Trucks towing capacity is not only based on the horsepower of the motor but also the brake system and axle capability. I am not sure, but since 07 was a model change to the NNBS they may have also upgraded the braking system.
    What I would like to look into would be to install the Banks Powerpack ( which has Ram Air, tuned headers, exhaust and the programmer ). I am told from Banks that it well increase my HP to 365 hp and torque by 70. The same truck with the 8.1 liter ( 340 hp / 455 lb-ft torque ) can pull 14000 lbs. I also know that the 8.1 has the Allison trans and my truck does not. I would like to be able to pull about 12000 lbs.
    Has anyone done this to a gas engine? If so what can you pull? Was the money worth the increase? Any information would help me.
    You might be able to "pull" that weight, but will you be able to stop it?
    This is critical. Speed and motion never killed or hurt anyone -- it's the sudden, unexpected stop in oddball places and against dangerous things that does.
    Presumably what's being towed has brakes on each axle (either electric ... or hydraulic over electric) and there's an appropriate brake controller in place. If so, then the stopping power is probably fine and we're back to load rating/capacity.
    12,000lb capacity is likely fine for a 9,000lb dry weight load ... plus passengers, fuel, cargo, and the like, as there's plenty of overhead in which to breathe. Exceeding 12,000lbs poses all the usual hazards of exceeding a mechanical and material design. i.e. Can the frame take it for sustained periods? Can the transmission handle it for sustained periods without overheating? What about the differentials? It's not just about the engine...
    As I said before. The 8.1 liter 2500hd is the same as my 2500hd only a different engine. Yes the trans is different, I know that and my truck has a temp gauge for the trans, so I will be able to watch the temp. As far as I know the frame, brakes, tires, drive line are the same for the 8.1 and 6.6 duramax in the 2500hd truck. My truck is a 2 wheel drive by the way.
  1. Banks Monster Single Exhaust System 48634
    Last Post: 09-10-2012, 05:10 PM
  2. Buying New 2012 Truck F250 6.2 Liter Gas vs. Sierra 2500HD 6 Liter Vortec
    By Todd00601 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-08-2012, 10:49 PM
    Last Post: 05-03-2012, 10:30 AM
  4. Banks Powerpack system.
    By 03 Black Sunshine in forum GM Powertrain
    Last Post: 04-30-2010, 09:16 PM
  5. Banks Ram Air
    By chevycamarado in forum Performance & Fuel
    Last Post: 08-30-2009, 09:04 PM
