Results 11 to 13 of 13
Thread: Tuners
    I would like to make it clear that I was not suggesting that you try to hide the fact that you had a tune from GM. As posted above, they will know. I was merely stating that a tune must be removed to do any diagnostic work.
    When I wrote this.....I never meant if the tuner caused a problem......I meant for any other issue not pertaining to the Tuner....All this has gotten blown way out...
    Proud Husband and Father.....
    Jun 2013
    ECS tunning services provide to thousands of cars and trucks with a myriad of modifications from basic bolt on like cold air intakes and high flow exhausts to wild big cube combinations with superchargers and turbos.EFI Live and HP tuners to dial your vehicle in so it has a steady idle, crisp throttle response, and yields greater power and torque across the entire RPM range.
    Last: 09-24-2012, 05:10 PM
  2. performance tuners
    By jams22 in forum Performance & Fuel
    Last: 07-19-2012, 04:55 PM
  3. Tuners in MS or AL?
    By LOBO in forum MS - Mississippi Chevy Club
    Last: 04-09-2011, 02:58 PM
  4. tuners
    By neilbachman in forum Performance & Fuel
    Last: 06-18-2009, 05:45 AM
  5. PCM tuners
    By ChevyFan in forum Performance & Fuel
    Last: 11-30-2007, 05:54 PM
