    Default New to Forum and Need Some Help
    hey guys i have a 2006 chevy 2500. sometimes when i go to start it after its already been warmed up i hit the key and it goes to start but dosent. teh starter makes a noise for a second and then you feel a clunk. then you go to start it again and it starts rite up. dosent do it every time but only when i have already ran the truck for a period of time. its doing it more often now so i am thinking its the starter. thanks
    Quote Originally Posted by justgm View Post
    justgm,
    Welcome to the forum! As Customer Service Representatives, we may be a little limited in the technical troubleshooting tips we can provide. Hopefully other members of the community will jump on here to help you out soon if you're hoping to resolve this without visiting a dealership.
    Just so we can better understand what resources to check, are you talking about a remote starter at all?
    Sarah (Assisting Evan), GM Customer Service
    Quote Originally Posted by GM Customer Service View Post
    justgm,
    no i do not have remote start. it does have the tap ignition thing where you just tap the key and it starts.
    justgm,
    Have you considered having your starting issues diagnosed at your local GM dealership?
    Evan, GM Customer Service
    It could be a starter relay issue or the starter itself. Hearing it clunk indicates to me that the solenoid is kicking the gear out but, the starter motor is not spinning. Sometimes when they start to go bad heat can be an issue. That could be why it only happens when it is warm. I would pull the starter, take it to a parts store and have it checked.
  1. Chevy Silverado Forum ~ Anyone know of a specific silverado forum?
    By kylegillean in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-20-2012, 05:19 PM
  2. New to forum and need some help
    By Hobbes in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-22-2011, 10:10 PM
  3. Hello everyone, new to the forum!
    By matthesenracing in forum Member Introductions
    Last Post: 03-10-2009, 11:45 AM
  4. New To The Forum
    By gazell in forum Member Introductions
    Last Post: 09-14-2008, 05:07 PM
