    Default rear window leak silveraldo
    Hi
    I got a 94 Chevy silveraldo 1500 extended cab , i have had the truck for 10 months and 2 weeks ago i noticed a few drips leaking inside on the rear window towards the pass. side,on the outside it has like a black weatherstrip seal i tried to sillycone it and it still leaks. i have 2 questions.
    1. how can i tell if someone tampered with the seal to cause it to leak?
    2. what can i put to seal the leak up?
    thanks
    Dog
    any window leaks may be from rust holes or the window was replaced and the installer created a rust condition by damaging the metal finish and not using the proper methods, . with a 1994 having window leak I would say it is a normal condition if your in the rust belt. the window need be removed and re installed to correct this. the metal must be perfect where the seal is.
    I had the same problem and the water was coming in from the 3rd brake light on the cab.
    Last: 02-02-2012, 06:10 PM
  2. Replies: 0
    Last: 01-24-2012, 06:00 PM
    Last: 01-10-2012, 06:40 PM
  4. Rear window defrost, repair possible or window replacement?
    Last: 03-02-2009, 07:18 PM
  5. 3rd door window leak
    By ras in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-06-2007, 11:43 AM
