Results 1 to 10 of 13
    Default engine temperature too low?
    Just wondering...
    For as long as I can remember My truck runs right at 185 degrees.. highway,city, you name it...
    Ive read alot that they are supposed to run at 210 degrees?
    Is this true? If so, does this pose a problem? could a 25 degree difference contribute to lost efficiency?
    thanks
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Somewhere north of 200 F, is the normal operating temp. A good indicater is the temp gauge in the dash, straight up, at 12 o'clock is the correct temp position.
    Yes, if not operating at the correct temp, the engine may not/will not run at the peak of it's ability. It will probably cost you at the pumps
    any probable cause of this you think?
    Oh, sorry I should have added that.
    It is usually the engine coolant thermostat.
    Probably a good time to also have the engine coolant flushed and changed as well.
    last time that was done was probably when my truck was totaled back on memorial day in '08, actually about 6 months later is when it was finally fixed, so been about 5 years because i know i havent flushed the coolant
    Check the fan too, if you have a clutch fan make sure it isnt locked up and running full time.
    i have the ls1 e-fans
    Just a toss-out here, that you shouldn't forget the obvious possibility that your temperature gauge is inaccurate. 185 constant seems VERY cool. As indicated by otheres, 205-210 is what you'll normally see. If fluid isn't doing it's job, usually the temp goes UP... Though at 5 years, there's a lot of other reasons to flush your system, too! (additives get used up in the antifreeze, and particulate build-up should be flushed).
    -Skippy
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
    It could be possible that a "fail safe" thermostat was installed last time. I hate those things! The guys at autozone talked me into putting one in my wife's cavalier back in 2002. He used the "it will never get stuck closed, so your motor will never overheat" I left it in for about 2 weeks! If we traveled anywhere we had to keep a blanket in the car. As soon as we drove over 40 mph the coolant temp would drop so the heater only blew cold air. I will never use a fail safe again. Many times they do not tell you that they are selling you a fail safe thermostat. Yes, not getting up to operating temp can damage you mpg. Like @RayVoy said the temp gauge should be straight up. (almost strait up, one line from strait up)
    thought i might add this for reference...
    its like this about ~80% of the time.... SOMETIMES it'll crawl up about 10 more degrees, on a hot day in traffic, but most of the time it looks like so
  1. Engine Temperature Guage Not Working
    By Royce 67/87/97 in forum General Chevy & GM Tech Questions
    Last Post: 08-05-2011, 10:28 PM
  2. Air temperature sensor
    By PRED888OR in forum Performance & Fuel
    Last Post: 05-02-2011, 02:02 PM
  3. What temperature does your engine run at?
    By Z28Johnny in forum GM Powertrain
    Last Post: 11-15-2010, 06:33 PM
  4. Temperature
    By Stealth in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-07-2010, 10:15 AM
  5. Coolant Temperature too low? Check Engine light..
    By gotacamaro in forum General Chevy & GM Tech Questions
    Last Post: 03-13-2009, 01:45 PM
