Results 11 to 17 of 17
    Quote Originally Posted by clinton_hedrick View Post
    Ah, I must have missed that. Thanks. Well, that sort of defeats the one of the advantages of a manual transmission. I wonder, If I disengage the clutch right after I engage it, it may start?
    If you dis-engage the clutch, the engine won't spin.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    Quote Originally Posted by redvett View Post
    The clutch switch only prevents the starter from turning not if you roll start the vehicle. If the battery is too low the truck will not start.
    That is a probability, I do not have a wiring diagram to check.
    That's what I thought. You should only have to disengage the clutch to turn the starter. But I've roll started completely dead vehicles, but it doesn't matter, I have tried to roll start the truck even with a god battery
    2000 Sierra Reg. Cab 5 Speed
    I was in a hurry, so I didn't have time to properly charge it. I haven't had problems with the batt/alt since then. It's just my old beater, if something would go bad with the starter or something else, I just want to be able to park it on a hill and go. Dad and I have had lots of trucks and tractor that are roll start only
    you need more than 9 volts to get the vehicle to start on a pop the clutch roll start. these vehicles need lots of amps when / to run like my 2000 requires about 50 amps with all lights ac off.
    as far as farm equipment goes that's not my area for sure. if the small engine has magneto then you need no battery power.
    j cat, a rolling start won't work with a charged battery either so the depressed clutch does more than disable the start relay. It is connected to the security system and disables the entire ignition.
    your correct on the clutch being depressed as that must be all the way down to permit start . just as automatic must be in neutral/park to allow a start condition. you would have to jump out the clutch switch . if your fast enough with the clutch I bet it is possible.
    I tried pumping the clutch in & out, and I got going a little faster and took my engine up to almost 3k rpm, but no good. The security light flashes. I guess it isn't a big deal now, the truck starts fine for me every time (given I dont leave a light on)
  1. hard start or wont start 305.
    By timhall1787 in forum General Chevy & GM Tech Questions
    Last Post: 09-29-2011, 09:00 AM
  2. Roll Bar
    By i am bob stoops in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-22-2010, 09:18 AM
  3. Roll pan
    By Kickerking817 in forum Chevy Truck Accessories
    Last Post: 08-17-2009, 04:18 PM
  4. Car was hard to start then didn't start at all
    By bmxr123 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-03-2009, 08:48 AM
  5. Roll bar (or whatever its called) for 07s?
    By NRAsticker in forum Chevy Truck Accessories
    Last Post: 11-30-2007, 09:07 PM
