    Default Serpintine Belt Chirp...
    I was going to mention this in my previous question but I didn't want to horse up either question. I've noticed some intermittent chirping, I previously had a 97 chevy silverado and feeling little off center going from a 5.7 to a 4.3. Thanks again!
    Welcome to the club, it's great to have you aboard.
    2002 Chevrolet Silverado Ext Cab 5.3 Liter / Automatic:
    Current Modifications:
    • Edge CS programmer w/Pod
    • K&N intake
    • Magnaflow exhaust
    • 2005 Tahoe grill with Grillcraft Stainless Steel SW series wire mesh insert
    • 2005 Tahoe Z71 valance under bumper with round fog lights
    • Recon LED Daytime Running Lights
    • Third Brake light is LED by IPCW
    • Tail lights are Spyder
    • Headlights are TYC
    • Front blinkers are Anzo LED
    • 6000K HIDs in headlights high beam, low beam and fog lights
    • LEDs everywhere else inside and out
    • Rear lights wired to work like the new Silverado with 4 tail lights, blinkers and brakes
    • Lowered 2" in the rear
    • Genuine GM 20" chrome wheels with 285-50-20 tires
    • Drilled and slotted rotors
    • Calipers painted to match
    • Kenwood DNX 6160 radio with Bluetooth, GPS, DVD, iPod, Back up Camera and satellite radio
    • 2 Cerwin vega amps "1400 watts total"
    • 2 - 10" Kicker subs in custom box under back seat.
    • 4 Infinity main speakers and 2 PB tweeters on front post
    • New custom paint job, Red Fire on Charcoal Gray
    "There's no fun in playing safe or by the rules, but it's not fun being hit by a semi-truck either."
    *****Thread Moved*****
    To The
    General Chevy/G.M. Tech Section
    99" SILVERADO
    Thank u! I'm trying to figure out how to navigate around, nice truck. I'm gonna work on getting some pics of mine up, catch u later!
    Look at belt, Is there any cracks? Missing gooves?
    08 Z71 Avalanche Mods to date: K&N CAI,Hellwig Swaybars and End Links, Corsa Sport Exhaust, Superchips Programer,IPCW LOF & 3rd brake light and tails, AMI Gas door,Show Hooks and Door locks, Enkei Wheels, with Pirelli tires, StreetScene Bowties, Grant Steering wheel,Muth signal mirrors,SSBC Big Brake kit,Huskyliner Mug gards,Floor mats and Hood shield, McGard Lug nuts and locks,Bedrug, Cervini's Ram Air hood,35watt HID Fog lights, Sylvania bulbs all around ZXE's Highs and Lows, WhiteNight Back up lights,Sirius and HD Radio, SnugTop painted and on, PerryCraft Rack system with Kayak and Bike Holder, Tempress Boat Hatches.... New Bilstein shocks on the way... New Mods coming soon..... X
    Dec 2012
    Minneapolis area
    Quote Originally Posted by Localsun77 View Post
    The tensioners, especially, are wear items and have to be replaced often. Take the belt off and see if there is any side play in the tensioner at all. If there is, replace it. Also check the idlers while you're in there although that's a less frequent source of trouble.
    Check for any oil or antifreeze leaks that may be contaminating the belt.
    If that's all OK try another belt. That will probably clear it up at first. Sometimes the belts fail without any visible damage. If the new belt starts chirping then check for damaged or misaligned pulleys. I worked on one car that ate belts and it turned out the previous owner had J-B welded the power steering pump bracket and the pump wasn't mounted square anymore so all the tension was on one side of the belt.
    Minneapolis area - 1997 K2500 regular cab long bed, pushes plow in the winter, carries camper in the summer - 2004 4x4 Suburban 2500 8.1, pulls 30' Airstream trailer
    It's a new belt and I don't see any type if fluid or condensation, I'm gonna pull the idler and see if that helps. Seems to be intermittent more than constant.
    Dec 2012
    Minneapolis area
    The chirps usually show up first when the alternator is under heavy load.
    You can turn the headlights on for a few minutes before you start your truck to load down the alternator (since it will try to recharge the battery) if you want to try to smoke out the problem.
    Another way to check is move the steering back and forth with the alt under load if the voltmeter drops that indicates slippage which will cause it to squeak.
    1996 Chevy Tahoe LT 5.7L V8 4X4 199,000+ miles. Built proudly at Janesville Assembly in Janesville, Wisconsin
    So took the truck to the dealer said no problems, bring it back it starts chirping. Brought it back to them of course the chirping went away, told them its on a cold start. They csll me bsck say we located problem it's the alternator $500. I said I'll be by to pick up my truck, mind u I have had it a shade over a week. Pick it up drive it home snd I got 12.4 amps in the battery, 13.9 when starting snd 15 when sccerlating with lights and radio on. It still chirps upon cold start? What y'all think?
    I had an increase instead of a decrease, it only does it on cold start up, so weird
  1. Update on serpintine belt
    By Localsun77 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-07-2013, 07:09 PM
  2. Chirp noise
    By vette66guy in forum GM Powertrain Tech
    Last Post: 07-04-2011, 09:07 AM
  3. Belt Chirp Squeak Not Squeal
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-19-2010, 03:11 PM
  4. 1992 C1500 Serpintine belt...Help
    By putski00 in forum General Chevy & GM Tech
    Last Post: 03-05-2010, 10:56 AM
