Results 1 to 10 of 11
    Default 100,000 Mile Maintenance?
    Hello everyone! I just bought a new to me 2009 gmc sierra and I have about 74 k in it. I was wanting to know everyone's opinion or advice for 100k maintaince, thanks!
    *****Thread Moved*****
    To The
    Maintenance Tech Section
    Hey thanks, nice to meet everybody, hoping to get some pics of my truck up
    Quote Originally Posted by Localsun77 View Post
    Depending on What Maintenance has been done to the Truck at this point "74K miles".......when it hits 100K Miles, you could look at some the following,
    ......A Cleaning of the MAF Sensor.....using CRC's MAF Sensor Cleaner
    ......^^^^^^^^^^^^^^ Throttle Body and Injector's
    .....A Flush of the.....Coolant, Brake, Steering and Diff. Fluids
    .....On the Transmission, Drop the Pan and Replace the Filter
    .....A New Set of Plugs-n-Wires and go with A/C Delco Iridium Tip Spark Plugs
    .....Check All Belts-n-Hoses, and Replace if needed
    .....Check the Brake Pads, Replace if needed
    I agree with what @99'HEARTBEAT posted. You may also want to check out the shocks.
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    York and Wilkes Barre, PA
    All the above and I would also look into changing the fuel filter
    Objects in mirror are losing
    Quote Originally Posted by KyleZ71 View Post
    I don't think that the fuel filters are changeable after 2004. My 05 has a filter in the tank
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    that may be a problem
    Correct.....
    starting in 2004" the Fuel Filter was moved to the Fuel Tank and is non-serviceable, with the exception of the Flex Fuel and the 4.3 V6. They were moved to the Tank in 2005" and now part of the Fuel Pump Assembly.
    I would also change the t-case fluid. I think that the recommended interval is 50,000 miles.
  1. Replies: 11
    Last Post: 10-05-2013, 10:52 PM
  2. 200,000 mile maintenance
    By Conlan Rose in forum Maintenance & Upkeep
    Last Post: 08-28-2012, 06:56 PM
  3. Maintenance
    By z3ro in forum Maintenance & Upkeep
    Last Post: 03-19-2010, 12:29 PM
  4. '01 maintenance?
    By 6camaro9 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-30-2008, 08:54 PM
  5. 4WD maintenance
    By Skarch in forum GM Powertrain
    Last Post: 10-10-2007, 04:12 AM
