Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
    That would not have happened had I been trying to keep up, but I didn't bother and, instead, flicked my lights to wave 'bye'.
    But, yes, you stomp on it whereas I just cruise along; I've never had the urge to drive quickly in a lifted vehicle ... so the gains of which you speak are not ones I'd feel/notice.
    I like space between me and other vehicles on the road, not that speeding is necessary....
    When I buy a vehicle, I buy it with the intention of driving it. If it means more wear and tear on the engine, then you replace those parts ( within reason ) before moving on to the next vehicle.
    If I wanted to garage the truck and make it a show vehicle on a pedestal; I would, but that is not the case.
    Since when did running 87 equate to garaging a truck and making it a show vehicle? LOL
    Quote Originally Posted by James4012 View Post
    I run nothing but plus or premium in my V-8. Old gramps told me to when I was real little and the old fool is a Chevy guru so I'm inclined to try what he says. Honestly, my truck is a ether baby now. It's ran out of gas a couple times before (gas gauge don't work) and I've had to put a couple gallons of regular I keep for emergencies in it. Wouldn't ever crank less I sprayed the filter with starter fluid.
    Interesting story, but irrelevant.
    It appears that this thread has stirred up quite a few somewhat emotional posts. While I do agree higher octane gasoline does make a difference in high performance vehicles, these are pickup trucks.
    Unless the manufacturer state premium required, running premium is pretty much a waste of money.
    Performance tunes are another valid reason to run premium gas as the tune will adjust engine timing for additional power.
    I have read a few posts in these threads that indicate that the user runs premium gas because it makes them feel better. If that feeling is worth ~$6 a tank more, go right ahead.
    The only actual difference I can honestly say I've seen between the two is "knock". I have data logged with hp tuners on all of my vehicles, 2.0 turbo, 6.0 vortec, 5.7 lt1, 5.7 ls1, and a 3.1. And when running 87 octane in each of these engines there is quite a bit of knock through out acceleration, when switched to 93 octane there is a considerablely less amount of knock in the engines.
    Certain amounts of knock can reduce timing, which could feel like less power. Your friend is not totally wrong, if you datalog your truck where you can actually see timing tables you will see what I am talking about. I use premium in them all, I drive 110 miles everyday to work and back so to me less knock is better....
    I've had many Chevrolet trucks.
    2.2L (S-10)
    4.3L (W/T)
    5.0L
    5.3L
    I even had a 4.0L Ford Explorer and none of them "knocked" during acceleration.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    2.2L (S-10)
    4.3L (W/T)
    5.0L
    5.3L
    If you really want to get down to raw numbers, you will need to get 2 stock silverado's that are identical in engine, drive train and weight.
    Fill one with 87oct and the other with 93 and then run some tests.....
    I will with 99% accuracy guarantee that the truck running the 93oct. will respond better, have better engine wear, etc than the one running 87oct. Even though 87oct is the "minimum" recommended octane for the 5.3L even if it is better by 0.5% better than the 93oct.
    Tuning the engine for 93oct. will increase that percentage to between 3-5% better. You also need to differentiate between gas with 10% ethanol and ethanol free gas, and the cost difference between all 6 of those blends.
    I look at it this way. I fill up once a week. depending on gas prices I sit at about $65-$88 per 22 gallons of gas.
    $5 more to go with 93oct is not going to kill me. Do you smoke or drink or drink coffee? $5 is less than what most people spend on 1 cup of coffee, and allot less if you have 2-4 cups a day.
    So the $5 is almost as meaning less and trying to compare the difference betwen 87 and 93 oct.
    If I would not burn up the seals and gaskets in the engine, kerosene for 101-110oct fuel is actually better, but you will blow a normal engine like our trucks have using that stuff in them.
    Do you have any empirical data to back up your claims?
    You and the manufacturer appear to disagree. Since the manufacturer knows about their products better than you or I do, I will go with their recommendation.
    The engine's fuel management system is perfectly capable of handling a lower octane fuel.
    Every study I have ever read is that the fuel mileage increase with premium gas in an engine that does not require premium gas is negligible. Certainly not worth the price difference.
    Wear better???!!!! As my British neighbor says, "bollocks".
    I'm not saying higher octane fuel does not have its place. If I was racing my truck, a few tenths of a second might be the difference between winning and losing. I don't race my truck, so premium fuel is not needed. I set my truck's cruise control at 65 on the highway and there is certainly no benefit of using premium gas for that.
    Even tho I use exclusively 87 for price reasons, it costs 20+ cents more for it per gallon in CT, in the 1996 Suburban/Tahoe manual it says use at least 87oct fuel and it is safe to use higher and it may reduce "knock" but if the engine is knocking bad on 87 service the truck immediately.
    In my opinion both are fine if your using the truck as a daily driver, but why spend the extra. This is coming from a very down to earth High Schooler who owns a 198,600+ mile truck that gets 12 on a good day and doesn't have a real job, so I'm as cheap/thrifty as possible. Also I think ethanol isn't all its cracked up to be... My truck normally runs on the reg 10% blend, but when I put the non-ethanol gas in the truck seems a little happier.
    Keep in mind my truck is bare bone stock in terms of its powertrain.
    From what I understand, the overwhelming majority of the gasoline sold in the US is 10% ethanol. I would love to find a station that sells ethanol free gas.
  8. #18
    Many in Vermont, Maine, New Hampshire, and up state New York sell it. This is because these areas get most of their gas from Canada not the refineries in New Jersey like the rest of the north east.
  9. #19
    There are a few stations here in Missouri that sell it (Google search), but they are way out in the country. I would have to drive for about an hour to reach a station.
  10. #20
    That's definitely not worth it. I only get ethanol free gas when in VT with the truck.
    Last Post: 07-17-2011, 04:10 PM
  2. Operation Overthrow! Unleaded Gas for $1.35/gal
    By TURBO2 in forum The Coffee Shop ~ Chit Chat
    Last Post: 05-28-2011, 04:33 PM
  3. 20 gallons of unleaded gasoline in diesel fuel tank
    By gmidiot in forum General Chevy & GM Tech Questions
    Last Post: 04-23-2011, 06:52 AM
  4. Aftermarket Fuel Pressure Regular
    By Silverado Junkie in forum Performance & Fuel
    Last Post: 03-30-2010, 10:38 AM
  5. Premium Fuel
    By duck44 in forum Performance & Fuel
    Last Post: 02-10-2010, 09:07 PM
