Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
  1. #41
    with the engines in these vehicles and operating with a light load you will not see much improvement in any way with the 93 octane.
    If your towing /hauling then the 93 octane does help with reducing knock which will reduce timing and cause low MPG/power.
    if you do a MPG test to compare the MPG between the two octanes also the increased cost of the 93 octane you will find the 93 costs more per mile than the 87 .
    some brands have detergents some do not. 93 octane of some no name brand does not mean it has any cleaners in it or burns cleaner. the engines are designed to burn clean with the OEM 87 octane fuel . if not then you fail the emission test/check engine light on.
    with any tuners/pcm tweaking 93 octane will make the engine run stronger but you have changed the PCM programing to run on the 93 octane.
    I run 87 unless I plan on towing my 4,000lb boat then 93 is used.
    the only place I could find non ethanol fuel was in Oregon state. perhaps Canada.
  2. #42
    Quote Originally Posted by JTward1 View Post
    Yes, The 18 amendment proved without a doubt how only elected idiots in Washington, whom can take the most accepted concept and destroy it. Of course they seek salvation by issuing the 22 amendment. Close to a hundred years later, here we are with flex fuel and the corner gas station offerings.
    The 21st Amendment repealed Prohibition. The 22nd Amendment limits the US Presidency to two terms. That Amendment is under scrutiny now as Obama supporters was him to run for a 3rd term.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
  3. #43
    Sr. Engineer nickgiacalone's Avatar
    Mar 2009
    Metro Detroit, MI
    If the vehicle doesn't say "Premium Fuel Only" I run with plain old 87 octane. I do not like the "Flex Fuel" tho, I think there is not enough savings compared to the lower mileage. Just my .02
    I do however run a can of SeaFoam thru my vehicle when I change the oil (roughly every 5k miles)
    -Nick
    2013 Silverado 1500 4x4 LT, Z71 Appearance Package, Vortec 5.3L AFM
    Victory Red, Ebony Cloth
    Custom pin striping, Bed Rail Protectors, GM Bed Liner, Husky Liner Floor Liners, Tint, Wade In-Channel Window Visors, Tractor Supply Black Low Profile Toolbox
  4. #44
    Exclamation
    MY mistake, Yes it was the 21st, but I think you get my drift ? . . . Or becomes a department unto itself.
  5. #45
    Quote Originally Posted by nickgiacalone View Post
    As you know, Flex fuel is every where in Michigan. But, I thought that the entire idea of flex fuel was to reduce foreign oil dependency and reduce fuel cost. I see E-85 often priced 5-10 cents lower than regular. sometimes it is more expensive than regular. For the mpg loss it is just not worth it. If it were $1 less a gallon then I may buy it.
  6. #46
    Sorry I didnt read umteeen hundred post in this thread but heres my 02cents.High milege engines require more octain while newer ones dont.Our engines are low compression which means they designed to run on 87 octain..I`lll run + or premium once in a while when I go on a road trip seems to run better and I get a couple more miles mpg.My truck is an older truck the ethanol in the gas is riuning parts in my tb.Its garbage our goevernment is forcing this stuff on us.The only place I can buy ethanol free gas is the boat marinas.
    While driving remember this rule of thumb,If another driver switches lanes infront of you cutting you off causing you to slam on the brakes to avoid a collision that they almost caused its your fault and you should be happy that they flip you the bird when you lay on the horn.
  7. #47
    Mar 2009
    Metro Detroit, MI
    I agree. Like I stated, if I was saving money or breaking even, I'd run it. But, I'm not going to run a "cleaner" fuel just to spend more in the long run.
    -Nick
  8. #48
    Quote Originally Posted by AC`s94chevy View Post
    Premium gas will not give you a 2MGP increase. You'd be lucky to see .1MPG increase.
    My new 2013 is flex fuel capable. I'd run E85, but the problem is that E85 is only $0.20 cheaper. I think the next time I fill up, I'm going to run a tank of E85 and see how badly my mileage is hit.
    I have been getting ~17MPG with mostly highway and some city running 87 octane E10.
    Mods:
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
  9. #49
    Try running high octane Aviation fuel itll increase your MPG but not enough to justfy the $8.64 a gl price tag.
  10. #50
    Run that for too long you your pistons while have nice holes in the middle of them.LOL
    [QUOTE=stchman;552220]Premium gas will not give you a 2MGP increase. You'd be lucky to see .1MPG increase.
    And you have driven my truck to know this?Because I calculated my mpg and that s how I came up with the figure.
    Last Post: 07-17-2011, 04:10 PM
  2. Operation Overthrow! Unleaded Gas for $1.35/gal
    By TURBO2 in forum The Coffee Shop ~ Chit Chat
    Last Post: 05-28-2011, 04:33 PM
  3. 20 gallons of unleaded gasoline in diesel fuel tank
    By gmidiot in forum General Chevy & GM Tech Questions
    Last Post: 04-23-2011, 06:52 AM
  4. Aftermarket Fuel Pressure Regular
    By Silverado Junkie in forum Performance & Fuel
    Last Post: 03-30-2010, 10:38 AM
  5. Premium Fuel
    By duck44 in forum Performance & Fuel
    Last Post: 02-10-2010, 09:07 PM
