    Default Help installing a Kicker Hideaway Sub in a 2012 Silverado
    Hello All,
    I want to install a Kicker Hideway Subwoofer under the rear seat of my 2012 Silverado Extended Cab.
    (Link: http://www.crutchfield.com/p_20611HS...S8.html?tp=114)
    To do this, I need to connect it's harness to two speaker's wires (a left and a right), and I'm assuming the rear speaker wiring would be the easiest to get to since I'm installing this under the rear seat.
    Any idea where I can find this wiring in the rear of the cab? Does it run up a panel somewhere that's easy to get to?
    Thanks!
    2012 Silverado 1500
    2004 Silverado 1500 (SOLD): http://tinyurl.com/JRD761sTruck
    1977 Silverado C20:
    http://tinyurl.com/JRD761-1977-C20
    The barn door speaker wiring should run along the back, up, and through a rubber accordian gasket to the speakers in the doors, just like the ones in the front doors (but in reverse). You'll probably have to pull the rear seating out, and probably the frame as well, to be able to pull the carpet back and pop the plastic covers off, to be able to get at the wiring.
    I would like to see pics and get your personal review of this sub.
    Mods:
    Advent OGM1 Navigation
    Airaid MIT
    EGR Rail Caps
    K&N Air Filter
    Flowsound 40 Muffler
    Chrome Tailgate Handle Cover
    TonnoPro HF-155 Tonneau Cover
    I'm more than likely going to be picking one up tomorrow. I had one in my 2004 and it was was pretty good. Wouldn't rattle the windows off, but it made the whole sound system sound way better.
    I don't want to get rid of the stock deck; it does everything I need it to do, and there's so much that goes through it (OnStar, steering wheel controls, ect) that I don't want to have to go through the hassle of getting 15 different things to make an aftermarket deck work. I'm hoping this addition will make the system a lot better..
    2012 Silverado 1500
    1977 Silverado C20:
    Sep 2011
    Fairbanks, Alaska
    Don't connect to a left and right speaker...you will give your subwoofer a stereo input signal and it will sound very strange with certain songs, subwoofers are not side dependent, run all signal wiring to one speaker and give your driver a mono input, mono is a signal type reserved for drivers and center channels.
    It's a powered sub that takes speaker level inputs, and has a built in signal converter. You don't need to install a seprate line-out converter for it (although you can). Subwoofers not being side dependent is also nonsense. If you have a single subwoofer and only hook it up to one side for input, you'll only get low frequencies from that side, and may miss some of the sound. This is why you need a mono amp, which downsamples the inputs from both sides, into a single channel for a single subwoofer, when using a single subwoofer. However, the Kicker hideaway sub in question has inputs from both sides, and downsamples it to mono for the single sub. So it won't sound particularly strange.
    Sep 2011
    Fairbanks, Alaska
    Frequency is NOT side dependent.
    It is when the audio track isn't in mono. If the audio track splits sound between left and right, it's going to split low frequencies just as it's going to split high frequencies. Low frequencies don't get sent at the same level across both sides, just because most people install a single subwoofer in their cars. It's still stereo, they just miss some of the music.
  1. For Sale 2007 and up Silverado Crew Cab sub box with Kicker Comp VT 10" Sub
    By SCampbell in forum Audio & Video Classifieds
    Last Post: 02-20-2013, 09:02 PM
  2. 2012 Canyon SLE- Installing double-din stereo
    By kasjrb01 in forum Audio, Video & Gadget Tech
    Last Post: 10-13-2012, 02:06 PM
  3. 2 10" Kicker L7's in a 2009 Chevrolet Silverado Crew... CAN IT BE DONE?
    By SavageMAC14 in forum Audio, Video & Gadget Tech
    Last Post: 06-21-2011, 03:10 PM
  4. Kicker
    By lsutoms in forum Audio, Video & Gadget Tech
    Last Post: 02-22-2010, 10:22 PM
  5. full kicker in 09 silverado swap out
    By 09lowrider in forum Audio, Video & Gadget Tech
    Last Post: 12-11-2009, 01:27 PM
