User Tag List
    Default 03 1500 - Bad Blower Motor or Electrical
    Hi Guys,
    Hoping someone can help me out. Have an 03 Suburban 1500. The rear ac/heat controls do not work at all. When turning them you can hear a click in the back. I removed the rear panel to access the blower motor and resistor. The clicking was coming from the resistor, so I purchases a new one at AZ for almost 100. Put it in and things blew great, for a minute. Then it was back out and back to the clicking sound from the resistor. Could the blower be bad and drawing too much, therefor blowing the resistor? Bad resistor out of the box? Other electrical problem? Any help would be greatly appreciated. Thank you in advance.
    Mar 2013
    adirondacks,n.y.
    havent heard of a bad blower motor taking out a resister,try the old swat with hammer on blower motor case,most often it is a bad spot,shocking it will confirm,otherwise take off connect and check for power
    How was the resistor wired? Sometimes they have a connector and they are plugged into the wiring, others require splicing into the wiring.
    If you have one with the connector, sometimes the new connector is plugged into a burnt old connector. Check the condition of the old connector that the new resistor connector is plugged into, if burnt, you will need a connector replacement kit.
  1. Trouble With Blower Motor 95 chevy 1500
    By ThomG in forum GM Electrical Tech
    Last Post: 06-23-2011, 09:44 PM
  2. 99 Suburban 1500 - where is blower motor resistor?
    By Gordon in forum General Chevy & GM Tech
    Last Post: 10-20-2010, 11:18 PM
  3. Blower motor ??'s
    By alkasmeltzer in forum GM Electrical Tech
    Last Post: 08-28-2010, 10:07 AM
  4. 2002 1500-Blower motor won't shutoff
    By shawnmd in forum General Chevy & GM Tech
    Last Post: 02-01-2010, 10:52 AM
  5. Chevy Suburban blower electrical problem
    By Sunny in forum Audio, Video & Gadget Tech
    Last Post: 12-20-2008, 10:29 AM
