User Tag List
    Default New guy with a fuel problem (I think)
    Hey guys, thanks for the opportunity to join the board. Hopefully i will get and give some good info. So here's my dilemma
    99 Suburban 2500 with a 454 bogs down bad while under load while giving it some throttle. It has a strong air sucking sound while it does this. I hooked up a fuel pressure gauge and here are the readings.
    Truck cold: ignition on truck not running 50psi and drops down to 22 in 5 minutes
    Truck cold: Running at 47psi
    Truck cold: 2000 rpms at 47psi
    Truck hot: 47psi
    No matter what rpm when hot or cold, it stays at 47psi. So i'm thinking its either the fuel pump or the pressure regulator. What do you guys think?
    Assuming the pressure gauge is accurate, it seems pretty certain that the fuel pressure is too low. As you suggest, the next step is to determine if the pump is weak or if the regulator is opening too soon. When I've diagnosed this, I used a C-clamp (or similar) to carefully clamp off the return line from the regulator back to the tank. If this causes the pressure to jump up, then the regulator is likely opening too soon. If this has no effect on the pressure, then the pump is likely too weak (or there is something else like a clogged filter preventing the system from generating sufficient pressure.
    Have you replaced the fuel filter? Clogged fuel filter can cause runnability issues.
    In addition to above, pull the vacuum line off the fpr. If fuel comes out of the vacuum line connection at the fpr, it is bad. The fpr diaphragm has ruptured.
    Lastly, fuel pump is getting weak.
    2011 Chevy Silverado LT 4WD 17k miles
    2001 Suburban 2WD, 5.3, V8 167k miles
    1993 964
    1996 318TI
    Fuel filter is 6 months old. I'll try and check the vacuum line, but getting to the actual unit without taking off the intake will be a challenge.
    New twist to the problem. I just discovered a puddle of rusty water under the truck coming from the water pump. I looked in the radiator to discover that it is quite low on fluid. So the next question is would low coolant cause the bogging? I was doing some reading on the coolant sensor and the entire engine performance is based on what that little sensor tells it.
    Mar 2013
    adirondacks,n.y.
    I would say youre pressure is low from pump,a good pump will build pressure slowly wwith clogged filter,and not drop that far down in that time span,regulators usually go on the high side.c.t.s needs acurate temp. reading.fill up coolant and see,can anyone say how long that the pump will continue same pressure,hard to say,Id do coolant leak first
  1. please help fuel problem
    By txtruck91 in forum General Chevy & GM Tech
    Last Post: 08-12-2012, 04:11 PM
  2. Fuel System Problem
    By AKRide907 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-01-2012, 04:02 AM
  3. Fuel Problem
    By Scott Alexander in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-28-2011, 10:39 AM
  4. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech
    Last Post: 12-13-2009, 05:38 PM
  5. Fuel problem
    By hogger38 in forum Performance & Fuel
    Last Post: 02-13-2008, 06:24 AM
