Results 1 to 10 of 12
    Default Rear End Squeaking?
    Hey guys! New here, so I'll start out by telling you I have a 2010 Silverado, 5.3 4x4. Reg cab....... My baby.
    Today, noticed a squeaking noise in the rear end. It sounds like rubber moving around, but I have no idea. It happens while moving slowly in reverse, and when accelerating at higher speeds. There is no vibration or anything else..... Just a god awful sound coming from the back.
    Someone mentioned a CV arm to me - Just wondered what you guys thought!
    If its the rear it isn't a CV arm.... There aren't any... It may be a brushing that has dry rotted or became misaligned. If I were you I would look over all the rear suspension brushings. and poke at them seeing how soft they are and make make sure they are not cracking or crumbling.
    1996 Chevy Tahoe LT 5.7L V8 4X4 200,000+ miles. Built proudly at Janesville Assembly in Janesville, Wisconsin
    I knew the CV arm thing sounded off....
    I don't think it's a suspension thing though.... It sounds like a rotating thing, and linked to how fast I'm going, and if accelerating or not.
    If it helps - I JUST had an oil change done. It's just funny I have it in the shop, and it comes out with this new problem. The truck is only 2.5 years old!
    Would it be a U-joint???
    It may be a U-joint. May be a bearing or seal. The only way to tell will still be feeling around the rear end of that truck. Check everything for extra play, dry rot, cracking, improper lubrication and just plain looking out of place.
    Mar 2013
    adirondacks,n.y.
    test drive with a passenger,listening from both sides that way,otherwise jack up and spin wheels one at a time,brake issue possibly?
    Check the u-joints and the fluid level in the rearend. It could be the rear brakes or the parking brake shoes inside the rear disc/drum.
    1995 Silverado 4x4 (Sold)
    I got under there - I reefed on the driveshaft both in and out of N - the U-joints are good and solid. Greased all the fittings I could find, and all the bushings and shackles are fine. It has to be something inside the wheel I guess.
    Bugging the hell out of me. I just had it into the shop for an oil change, fluids and inspection. That was Thursday.
    Mar 2013
    adirondacks,n.y.
    automatic trans?leave out parking brake,dont use it,correct?otherwise do wheels off the ground spin by hand test,another idea is to hose out inside rims,brake area to remove foreign debris,both easy checks,hope it helps
    @geo1 he should still check the parking brake. Even if he doesn't use it it may cause a problem. Also its a smart idea to use your parking brake it removes strain from the tranny and makes sure that if your vehicle is improperly towed or attempted to be stolen from you the transmission wont be ruined if they try to drag it from the front.
    Mar 2013
    adirondacks,n.y.
    yes,you are correct,is there a quarter jar on here somewhere?i owe it one
  1. 04 Silverado rear wheel squeaking
    By 04ChevySilverado in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-12-2013, 10:29 AM
  2. Rear Wheel squeaking at low speed
    By mac daddy in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-05-2013, 03:35 PM
  3. Squeaking problems
    By whodeywhat in forum Lifted & Offroad Suspension
    Last Post: 10-19-2012, 02:20 PM
  4. Squeaking springs
    By SWAT13 in forum Lifted & Offroad Suspension
    Last Post: 08-07-2012, 11:03 PM
  5. Squeaking, maybe from suspension?
    By Crakums_GT in forum Lifted & Offroad Suspension
    Last Post: 07-28-2009, 07:30 PM
