Results 11 to 12 of 12
    Quote Originally Posted by brentwal View Post
    Hey guys! New here, so I'll start out by telling you I have a 2010 Silverado, 5.3 4x4. Reg cab....... My baby.
    Today, noticed a squeaking noise in the rear end. It sounds like rubber moving around, but I have no idea. It happens while moving slowly in reverse, and when accelerating at higher speeds. There is no vibration or anything else..... Just a god awful sound coming from the back.
    Someone mentioned a CV arm to me - Just wondered what you guys thought!
    Here's a G.M. Service Bulletin, its regarding.....
    Squeak Noise from Rear of Vehicle......weather or not this bulletin, is talking about the Same Squeak Noise your Silverado Has, I don't know, but I felt it was worth posting-up, as you mentioned, you have a Squeak Noise, hopefully this Bulletin may be able to help??
    | Document ID: 2732835
    #06-03-09-004D: Squeak Noise from Rear of Vehicle (Lubricate Rear Leaf Springs) - (Nov 1, 2011)
    Subject: Squeak Noise from Rear of Vehicle (Lubricate Rear Leaf Springs)
    Models: 1999-2007 Chevrolet Silverado (Classic)
    2007-2012 Chevrolet Colorado, Silverado
    1999-2007 GMC Sierra (Classic)
    2007-2012 GMC Canyon, Sierra
    2007-2010 HUMMER H3, H3T
    This Bulletin is being revised to add the 2012 model year. Please discard Corporate Bulletin Number 06-03-09-004C (Section 03 – Suspension)
    Condition:
    Some customers may comment about a Squeak Noise coming from the Rear of the Vehicle. During normal operation, certain vehicles may exhibit a squeaking noise that may be traced to the rear leaf springs. While this noise is an operating characteristic of leaf springs, the frequency and severity of this noise will be affected by the roads that the vehicle is driven on.
    Cause:
    This condition may be due to debris getting between the leaf springs.
    Correction:
    To correct this condition, lubricate the rear leaf springs using the following procedure.
    Important:
    It has been found that the application of grease to the rear leaf springs does a better job of preventing the noise from reoccurring than replacement of the spring.
    1. Raise the vehicle on a frame lift-type hoist.
    2. Inspect the springs for damage. If none is found, proceed to the next step.
    3. Pressure wash the rear leaf springs to remove as much dirt and grit as possible.
    4. Dry the springs with compressed air.
    5. Apply a liberal amount of grease, P/N♦12345996 (in Canada, use P/N♦10953501), both underneath and on top of the front and rear tip inserts for the #2 and #3 leaves. A screwdriver can be used to gently pry up the tip insert; however, a rag around the screwdriver must be used to prevent damage to the spring. Use a flat-bladed tool, such as a gasket scraper to properly distribute the grease.
    6. Lower the vehicle to the ground and test drive to verify the repair.
    *****Please inform the customer that this will offer relief, but is not a lifetime repair. Periodic cleanings and grease re-application may be necessary throughout the life of the vehicle.
    Good call @99'HEARTBEAT ! My 02 silverado had a squeak in the rear when hitting bumps. I noticed it after traveling down a dirt road. I pressure washed the leaf springs and sprayed the crap out of them with lubricant. The squeak went away for a while, whenever it would return I just resprayed them.
  1. 04 Silverado rear wheel squeaking
    By 04ChevySilverado in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-12-2013, 10:29 AM
  2. Rear Wheel squeaking at low speed
    By mac daddy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-05-2013, 03:35 PM
  3. Squeaking problems
    By whodeywhat in forum Lifted & Offroad Suspension
    Last: 10-19-2012, 02:20 PM
  4. Squeaking springs
    By SWAT13 in forum Lifted & Offroad Suspension
    Last: 08-07-2012, 11:03 PM
  5. Squeaking, maybe from suspension?
    By Crakums_GT in forum Lifted & Offroad Suspension
    Last: 07-28-2009, 07:30 PM
