Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
  1. #31
    well that's what I'm feeling is the piston misfire . I'm thinking my lifter is bad.i couldn't see that my cylinder would be hydro locked . I'm going to soak some b12 chemtool down all the lifters and do a engine flush to clear this up. I also noticed my spark plug was wet . unburned fuel noticed big time .
    2005 chevy reg cab 2500 6.0l
    bds 7" ntbd high clearance kit
    7%tint 15% Windsheild tint
  2. #32
    when a rod is bent that much you have more than a lifter issue. the piston wacked that valve which bent that rod. Hydo-lock meaning the cylinder when sitting shutdown for a time filled with a fluid. then on starting the valve pushes so hard on the rod, it then bends.
    or the piston breaks off and wacks the valves bending the rods. if this is only ONE cylinder this is what / why I think this is the cause.
    in any case the engine will require a breakdown to inspect the cam. see what else got damaged.
    you could try to just put another rod in see what happens.
  3. #33
    Well I started to disagree with j.cat but what is done is done and all that can happen is you lose another lift rod, but I would bet on internal damage that means a teardown plus I would wonder when the darn thing would turn loose again.
  4. #34
    yep decided to pull the motor checked the top if piston and she's scored and piston has turned in the cylinder . so only thing to do is to pull the motor. I have a local engine shop that are Awesome old schoolers that rebuilt my older brothers trailblazer ss . so I'm going to do as much as I can then send her there for a complete rebuild
  5. #35
    Quote Originally Posted by yeevveey211 View Post
    the piston breaking off the crank is not all that common with these engines.
    It is possible though the hydro lock issue may have caused this . also if the piston rusted to the bore. the pistons rusting to the block is a common problem with over wintered boat engines.
  6. #36
    how would a piston turn inside the cylinder? the markings are all in line except that piston
  7. #37
    since the piston rotated you should be able to pull it out .crank the engine see if the piston goes up/down my guess is no.
  8. #38
    Mar 2013
    adirondacks,n.y.
    great god,still thinking a leaking injector is at fault?sorry to hear of this news,no way telling when turning the key
  9. #39
    ya not fun I have everything off ready to pull out as soon as this weather is nice. I guess another bump in the road you gotta go over . keep ya guys posted
  1. Engine Knock Sensor help!
    By 2003-5.3-V8 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-30-2011, 03:23 PM
  2. Hot Engine Knock
    By Lil_Red_Chevy in forum GM Powertrain
    Last: 06-09-2011, 11:42 PM
  3. Engine Knock - Not Piston Slap
    By fargo_182 in forum GM Powertrain
    Last: 05-10-2010, 02:22 PM
  4. '97 silverado engine knock
    By digger4x4 in forum General Chevy & GM Tech Questions
    Last: 12-21-2009, 10:29 PM
  5. 5.3 engine knock
    By treefarmer in forum GM Powertrain
    Last: 01-27-2008, 03:45 PM
