Results 1 to 10 of 13
    Default Dimming Head Lights Help ?
    Hey all, I have a 2004 GMC 2500HD Crew Cab Duramax and every now and then the head lights will dim almost like they do when your anti-lock's kick on. I have replaced both battery's and put a new high output alternator on the truck and i am still having issues with the head lights dimming. Also it's not showing any defect codes on the computer.
    2004 GMC 2500HD Crew Cab Duramax Fire Dept POV / Work Truck
    I suppose this only happens when the truck is being driven. What will the voltage gauge do when this happens?
    Quote Originally Posted by Mainefirefighter View Post
    Are you saying, every thine the ant-lock brakes kick in the headlights dim?
    What else is in the truck? Lights, Stereo, inverter Eta???
    Only when im driving, nothing major except some led's but even when the master is shut off to all the accessories it still dose it.
    yes no voltage gage movement and the antilocks dont feel or sound like they come on
    Check all grounds first You said you up graded the Alt? What did you go with? Did you upgrade the Wires too?
    it did it before i replaced the alt and battery's too and all grounds are fine
    You did the Big 3? Main grounds and Power wire?
    Correct, iv been thinking would a bad wheel sensor be triggering the anti locks just enough to dim the lights ?
    Anti locks should not be dimming the lights. You might have an internal problem in the ABS computer that is overloading the electrical.
    Pull the ABS fuse, see if the problem goes away.
    And a note, a bad wheel sensor will normally turn off the ABS
    Had the whole ABS computer replaced cost me $600 installed and it did it before and after
  1. Dash lights "dimming" and other odd electrical issues
    By Bowtied in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-01-2013, 03:46 PM
  2. Head lights ? What head lights ? What happened to my head lights ....
    By DOBERDEWD in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-31-2011, 08:35 PM
  3. Low Voltage, Dimming lights.
    By 03HeavyHalf in forum GM Electrical Tech
    Last: 02-21-2011, 09:45 AM
  4. Dimming head lights?
    By s5belford in forum General Chevy & GM Tech Questions
    Last: 12-10-2009, 10:09 PM
  5. Dimming Dash Lights
    By MeanGreenMachine in forum General Chevy & GM Tech Questions
    Last: 07-13-2009, 02:12 PM
