Results 1 to 2 of 2
    Default 2001 Suburbn rear brake pad replacement
    I already finished the front pads. The front caliper is held by 2 torx bolts and guide pin as one assembly to the bracket. Once the guide pins were out, the caliper pulled out really easy,
    I am having a problem removing the rear caliper to bracket 12mm hex heads. The guide pins are held by 12mm hex head instead of torx head and the hex head bolt just keeps spinning and not unscrewing. It's not the same guide pin design as the front.
    Any tip how to get the rear caliper off?
    I figured out. There are two separate pieces to the rear caliper guide pin not like the one piece in the front caliper. I had to hold the inner guide pin with a small thin wrench while loosening the 12mm hex head bolt. The inner guide pin has a flat spot for an open wrench.
    1993 964
    1996 318TI
    Glad you found out the fix. I just did my brakes all the way around and it took me a bit to figure out the rears. but trying to install the new split back covers and parking brake hardware was much more of a task.
  1. What size brake front-to-rear-brake line?
    By NorthJersey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-25-2012, 01:43 PM
  2. 2001 2002 Chevy Silverado 2500 Rear Brake Rotors & Pads
    Last: 02-24-2011, 08:50 PM
  3. 2001 Suburban brake problem need help to change rear backing plate
    By superbrat in forum Lifted & Offroad Suspension
    Last: 10-23-2010, 07:55 PM
  4. Wierd rear brake valve linked to rear axle housing..what is it?
    Last: 01-31-2008, 01:56 AM
  5. the rear deflector thats on top rear above 3rd brake lights [Expired Topic]
    By 97bigredburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-13-2005, 12:34 PM
