    Default Getting Driver's side door panel off
    I need to get the ndriver side door panel off to get at the heated seat switch. Does anyone have any idea's so I don't brake anything. Thanks Eric
    Master Mechanic SupplySgt's Avatar
    Feb 2010
    Middle TN, displaced Okie
    There should be plastic clips holding the door panels to the doors. My Burb works that way as well as the 96 Sierra I used to have. I imagine the NBS body style works the same way. Just be easy on the panels when you pull it off and you'll be able to get it back in. From my personal experience in building automotive parts that use plastic clips, it might help to use a knife to pull the tabs on the clips slightly out (not enough to break them) when you secure the panel back to the door. They work in the same principle as the clips I use at work to attach the backboards of the seats to the metal back frames of the seats.
    93 Suburban (Southern Slayer): TBI 350, 4L60E
    73 Z28 Camaro: L82, TKO 600
    KJ4CLI
    "...Death smiles at us all, all a man can do is smile back..."
    What year and model is your truck?
    I took both interior door panels off my 2001 Silverado this past December to install new speakers. First remove the window/lock controls then there are a couple of screws at the very bottom to remove. Once you have done both of those steps, the panel should just lift up and off.
  1. Chevy silverado 07 08 09 10 11 door panel left driver manual
    Last Post: 10-23-2012, 09:50 AM
  2. Driver side door problem
    By tamiller72 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-28-2011, 11:23 AM
  3. Driver side door won't open from outside
    By touque in forum General Chevy & GM Tech Questions
    Last Post: 09-01-2009, 03:06 PM
  4. Driver Side Door Panels
    By MarlboroMan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-04-2009, 03:29 AM
  5. Removing driver door panel on 1999 tahoe
    By rgulbrandsen in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 06-02-2007, 10:04 PM
