03-18-2013, 11:32 AM #1
Transfer Case front output shaft seal leaking after replacement
My transfer case from Hades situation continues to by my Achilles heel.
Any ideas what would cause a front output shaft seal on a transfer case (NP 246) to go bad after being replaced? I just had the seal replaced about 3-4 weeks ago and the seal that was in there was supposed to be new when I got t-case, but it started leaking after a little time. Could there be something wrong with the actual output shaft/spline?
It's back at the shop now that replaced the seal a few weeks ago, so I'm waiting to hear what they have to say.
Thanks,
Sean
Family Force 6:
99 Chevy Suburban- the family truckster
93 Lincoln Town Car- has turned me into a fan of the Panther platform
Looking for a Volvo 240 manual (wagon or sedan)
Former GM cars:
78 Suburban 2WD 454- a towing beast!
71 Buick Electra 225 (the deuce and a quarter)
75 Monte Carlo- 400SB- biggest/heaviest doors GM every made!
70 Impala coupe- my first car
03-19-2013, 02:19 PM #2
Well,it appears to have been leaking between the seal and the case. They used some silicone around the inside of the case as there were small pits and scratches and installed a new seal (this will be the third one).
If this seal leaks I guess I'll start looking for another t-case. What a PITA this has been.
03-20-2013, 12:53 AM #3
Who manufactured the seal? I ask because I just had a rear seal replaced (with a NAPA part) .. and it leaked like mad despite being brand new. So, it was replaced -again- with an OEM part and there was no issue. Apparently this is common, as another forum user (dsfloyd) had run across the same thing.
The OEM rear seal cost about 3x as much as the NAPA part ... but was visibly superior in quality.
Perhaps your front seal issue is similar in nature? I'm merely speculating ... but if you've got a leaky front seal and it's not OEM, maybe give the spendy OEM part a look and if it's an obviously better seal ... perhaps spend the cash on it and put it in and see if it makes a difference?
2004 GMC Sierra 1500 5.3L V8 4x4 SLT Extended Cab Long Bed
(Garage Link: http://www.gmtruckclub.com/forum/sho...MC-Sierra-1500)
NRA Certified Instructor, Range Safety Officer, & Benefactor Member
"I have sworn upon the altar of God eternal hostility against every form of tyranny over the mind of man." -- Thomas Jefferson
"The only difference between the topic police and the thought police ... is spelling." -- Anonymous
03-26-2013, 05:23 PM #4
Not sure who manufactured the seal since the shop ordered it in. The shop did say that they occasionally get a bad seal, which based on your comment makes me think they don't use OEM.
So far it's not leaking, but the last won't didn't leak until it had been in there for 3 or 4 weeks. We'll see.
Transfer case, front drive shaft, or what? Any ideas?
By wbmartin3 in forum Chevy Suburban Forum (GMC Yukon XL)Replies: 9Last Post: 03-16-2012, 11:49 PM -
Transfer case front seal
By BReeves in forum Chevy Silverado Forum (GMC Sierra)Replies: 2Last Post: 02-25-2012, 11:58 AM -
Output shaft seal
By thejms in forum GM Powertrain TechReplies: 5Last Post: 05-09-2009, 02:05 PM -
output shaft seal
By Dangeruss88 in forum GM Powertrain TechReplies: 0Last Post: 04-29-2009, 08:08 PM -
WTB 241c Transfer Case & Front Drive Shaft
By homer911 in forum General ClassifiedsReplies: 0Last Post: 02-16-2009, 10:25 PM
VIGIL
Bookmarks
