03-19-2013, 12:08 AM #1Sr. Apprentice
- Join Date
- Mar 2013
- Location
- Franklin, TN
- Posts
- 42
Hum thru L/F speakers w/ headlights on
My 2010 Silverado 1500 LT has a hum thru the l/f door speaker and tweeter if the headlights or parking lights are on, but not during the daytime in auto mode with DRLs on. Anyone hear of this before or have a clue what could be the cause? The him does not change volume or change frequency with engine RPM. I just bought it and everything appears stock although I did see pics of this truck with blackout taillights that were changed back prior to my purchase.
03-19-2013, 09:54 AM #2
03-19-2013, 02:09 PM #3Sr. Apprentice
- Join Date
- Mar 2013
- Location
- Franklin, TN
- Posts
- 42
03-19-2013, 03:03 PM #4
with the radio off and its hum/buzz then pull the radio out and check the wires for shorts.
03-19-2013, 04:47 PM #5
The 2010 trucks have the speakers on whenever the truck is on (as well as the retained power feature). The radio is only one of the devices that use the speakers. Onstar and the chime alarms also need the speakers, the amps are used by the 3 systems.
I'm going to suggest that if the previous owner darkened the tails, perhaps he installed HIDs in the front. They may still be there, maybe removed and the transformer was left behind and connected. It sounds to me like a transformer hum.
If no indication of HIDs in the truck, check the headlights for a bad/dirty ground.
If that doesn't help, start pulling fuses that are part of the external lighting systems, do it one at a time until the hum stops.Ray
03-19-2013, 11:27 PM #6Sr. Apprentice
- Join Date
- Mar 2013
- Location
- Franklin, TN
- Posts
- 42
Thanks, yes- I have noticed that at night, even after shutting the headlights off, that the hum continues until I open the drivers door, terminating the retained power feature. Interesting. No HIDs installed now and will check for evidence of anything left behind but no apparent evidence at this point. So I'll check the headlamp grounds, then start pulling fuses- there may even be a dirty fuse connection that is increasing amperage to a device utilizing the l/f speakers.
Good places to start. Thanks kindly.
03-20-2013, 12:25 PM #7
a dirty fuse or loose fuse would reduce current to a device not increase. grounding check is a good idea. also as I mentioned checking the speaker wires for a short to ground.
could be in the amp unit .
update : sure can be the radio . did some looking and the radio units have these type issues. cooling fan etc.. in the unit.Last edited by j cat; 03-20-2013 at 12:42 PM.
03-21-2013, 09:20 PM #8Sr. Apprentice
- Join Date
- Mar 2013
- Location
- Franklin, TN
- Posts
- 42
Pulling the fuses for any of the lights, the radio, or the amp don't stop the hum. In fact pulling the amp fuse made it louder. Today I pulled the #15 fuse on the dashboard fusepanel for the BCM and the hum stopped. I want to pull the fuses for the several body harnesses on the fusepanel under the dash to see if the hum is localized within one of those circuits, but I can't get the darned fusebox cover to come off, so apparently there's some safety device keeping it on I haven't figured out yet.
new speakers
By reggiecab2000 in forum Audio, Video & Gadget TechReplies: 7Last Post: 06-20-2012, 02:44 AM -
Best Speakers To Replace Stock Speakers?
By MentalMike in forum Audio, Video & Gadget TechReplies: 23Last Post: 11-02-2010, 07:20 PM -
need help with speakers....
By DSpivey in forum Audio, Video & Gadget TechReplies: 3Last Post: 11-19-2009, 10:05 AM -
4x6 Speakers
By PearlWhiteGT in forum Audio, Video & Gadget TechReplies: 11Last Post: 08-03-2009, 12:46 PM -
speakers
By Silveradogearhead in forum Audio, Video & Gadget TechReplies: 6Last Post: 02-08-2009, 05:10 PM
Bookmarks
