Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Quote Originally Posted by GiddieUp View Post
    I got a 7 in lift with 315s and its got about 146k and I haha that's the problem I gotta buy a lift floor Jack to get the truck in the air and what would spinning the rear wheels do?
    7 inch lift and there was no drivetrain modification??? that seems awful risky....
    it would allow you to spin the driveshaft and listen to see if the noise is coming from the transmission, or the rear end, or transfer case, or wherever... you cant spin the driveshaft with the wheels on the ground AND be under it
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  2. #22
    Mar 2013
    Lynchburg Va
    Well the lift came with a bracket so you didn't have to mod the drive shaft but the place that put it on said it could be the drive shaft because its not long enough
  3. #23
    well we need someone to chime in with more experience on lifts and drivetrain modification, but i thought at 6 inches you were supposed to lengthen the driveshaft, not sure though
    I can tell you that even a three inch lift kicks the driveshaft back about 1.5-2 inches as you can see in my video
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
  4. #24
    Mar 2013
    Lynchburg Va
    So pretty much the noise could possiblybe the front drive shaft
  5. #25
    anything is possible, BUT at 7 inches of lift I would definitely get on google and research the poop out of that right now
    lets see if @SurrealOne knows, i believe he has a 6" lift on his sierra
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
  6. #26
    Mar 2013
    Lynchburg Va
    I talked to a guy that got the same lift asmine and he listened to the video and he said he had the same noise and I could be the exhaust hitting the cross member
    I also emailed the company about that to see if it they had any problems
  7. #27
    I had a 6" on my 95 and the drive shafts did not have to be modified at all. The exhaust did have to modified from where it came off of the driverside manifold and crossed over to connect near the passenger side. I wonder if the front drive shaft is rubbing your exhaust. What brand lift kit is it?
  8. #28
    Mar 2013
    Lynchburg Va
    Well the lift said there was no need of cutting or manufacturing of the exhaust but the guy I talked to had to do it and he has the same yeat and its a McGaughys lift kit
    My best guess would have to be the drive shaft not being long enough because it never made that noise before
  9. #29
    No grind/rattle, here. I've been quietly reading this thread and am baffled, too. I was waiting for a vid with sound...
  10. #30
    Mar 2013
    Lynchburg Va
    I posted one with the noise
  1. 06 chevy silverado 5.3L making weird tappin noise
    By jobrien836 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-27-2012, 12:51 PM
  2. Weird "grumble" noise at part throttle...
    By travisn in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-10-2011, 09:47 PM
  3. 02 Silverado has weird buzz noise when it shifts?
    By bassfish18 in forum General Chevy & GM Tech Questions
    Last Post: 05-29-2011, 01:09 AM
  4. 04 Silverado Drip or Click (Weird Noise)
    By OneWheelWonder in forum General Chevy & GM Tech Questions
    Last Post: 01-23-2011, 11:35 AM
  5. weird noise
    By swoop in forum General Chevy & GM Tech Questions
    Last Post: 11-29-2009, 01:14 PM
