Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
    Mar 2013
    Lynchburg Va
    Yea the shop told me to bring it back after 500 miles to make sure the bolts on the lift haven't come loose and they checked it and said they could not find out the nois
    if the noise is that evident and the shop can't figure it out then I would be questioning the ability of said shop. Was it a detail and accessory shop?
    Mar 2013
    Lynchburg Va
    They specialize in putting lifts and drop kits on trucks its the only place in my town where you can get lifts on
    Here are a couple videos of the noise.
    Mar 2013
    Lynchburg Va
    thats the sound it makes
    does the noise go away when you put it in 4wd?
    It sounds a lot like the sound that @reggiecab2000 had on his truck. Here is his post and video. http://www.gmtruckclub.com/forum/sho...=reggiecab2000
    Try listening to the video in the above link and see if it sounds like yours.
    It turned out to be his transmission.
    I have compared your vid and his multiple times. Thru my computer speakers they sound pretty close in sound. Yours seems slightly higher pitched.
    Mar 2013
    Lynchburg Va
    I don't know what it sounds like it 4wd. The truck didn't make this noise till I got the lift on I don't know if the drive shaft is not long enough or what
    I don't know if the trans because it doesent slip or anything like that
    His did not slip either. It was a damaged bearing inside causing the noise. Do they sound the same to you?
  8. #18
    Mar 2013
    Lynchburg Va
    Somewhat but mine does not do it in reverse and his sounds like more of a clunking noise like sounds like something is hitting something else
  9. #19
    i had a needle bearing go bad, yet even with that noise you could hear on mine, my truck drove perfectly fine, but with that noise i did not want to risk damaging anything else.
    how big of a lift did you get and how many miles do you have?
    i would say to do what i did, lift up the rear wheels and spins them with a friend in the drivers seat and listen around for where its coming from
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  10. #20
    Mar 2013
    Lynchburg Va
    I got a 7 in lift with 315s and its got about 146k and I haha that's the problem I gotta buy a lift floor Jack to get the truck in the air and what would spinning the rear wheels do?
  1. 06 chevy silverado 5.3L making weird tappin noise
    By jobrien836 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-27-2012, 12:51 PM
  2. Weird "grumble" noise at part throttle...
    By travisn in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-10-2011, 09:47 PM
  3. 02 Silverado has weird buzz noise when it shifts?
    By bassfish18 in forum General Chevy & GM Tech Questions
    Last Post: 05-29-2011, 01:09 AM
  4. 04 Silverado Drip or Click (Weird Noise)
    By OneWheelWonder in forum General Chevy & GM Tech Questions
    Last Post: 01-23-2011, 11:35 AM
  5. weird noise
    By swoop in forum General Chevy & GM Tech Questions
    Last Post: 11-29-2009, 01:14 PM
