Page 4 of 4 FirstFirst ... 234
Results 31 to 34 of 34
  1. #31
    I could kind of hear the noise in the vid. so here is my best guess. As others have stated (and as I had to do with mine) the drivers side pipe had to be extended below the flange a couple inches as the front driveshaft would hit the crossover pipe. You can see if there is any rubbing on the top of the crossover where the front driveshaft would hit. The extension or dual cardan front driveshaft that is typically recommended with these lifts is due to possible vibrations at higher speed in 4 wheel drive. I didnt do this as I dont typically drive high speed in 4 wheel drive and even when I did never noticed much vibration.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  2. #32
    Mar 2013
    Lynchburg Va
    So I should check the exhaust and the front of the drive shaft and see if anything is rubbing
  3. #33
    I would. its a fairly quick easy check and a cheap easy fix.
  4. #34
    Mar 2013
    Lynchburg Va
    I really hope its that haha
    Well I checked the exhaust and the frontof the drive shaft and they are close together but not enough to make that noise It's making
  1. 06 chevy silverado 5.3L making weird tappin noise
    By jobrien836 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-27-2012, 12:51 PM
  2. Weird "grumble" noise at part throttle...
    By travisn in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-10-2011, 09:47 PM
  3. 02 Silverado has weird buzz noise when it shifts?
    By bassfish18 in forum General Chevy & GM Tech Questions
    Last: 05-29-2011, 01:09 AM
  4. 04 Silverado Drip or Click (Weird Noise)
    By OneWheelWonder in forum General Chevy & GM Tech Questions
    Last: 01-23-2011, 11:35 AM
  5. weird noise
    By swoop in forum General Chevy & GM Tech Questions
    Last: 11-29-2009, 01:14 PM
