User Tag List
Thread: Where's the o2 sensor
03-20-2013, 03:51 PM #1Jr. Apprentice
- Join Date
- Mar 2013
- Posts
- 17
1987 r-20 with 254ci
i can't seem to find the O2 sensor. Any help?
03-20-2013, 11:05 PM #2
Did they even use 02 sensors back then?? I don't think they did, but besides the point what is an r-20??
03-20-2013, 11:37 PM #3
I am pretty sure that R-20 refers to the model of the suburban. The original poster would be better off just calling it a 1987 3/4" ton Suburban as no one knows what the heck an R-20 is. I think that he meant 454 not 254. I did not think that O2 sensors were used back then. But, looking at the autozone website they say that they sell them for that truck and motor
To find your O2 sensors follow the exhaust. If they are there they will be in the exhaust pipe somewhere. That is is the owner before you did not remove it.
1995 Silverado 4x4 (Sold)
03-21-2013, 10:56 AM #4Jr. Apprentice
- Join Date
- Mar 2013
- Posts
- 17
Sorry was in a hurry. Did not edit the post. It is a 454. R-20 is 3/4 ton rear wheel drive. When I got it smogged here in California the mechanic told me that it had a bad O2 sensor because it surges a little and gets poor gas mileage. I will look closer but so far have not found it.
it is getting about 8 miles per gallon on the hiway and I think it should be a little better on the hiway. this is a new truck to me that I bought just to tow a camper. Thanks for the responses
03-21-2013, 12:42 PM #5
a 454 3/4 ton getting 8 mpg highway is a little low (closer to city mpg). if there are 02 sensors there would be one before and after each catalytic converter (once again if it has either of those in that year). Basically will look like a spark plug sticking out of the exhaust with a couple wires out of the top.
David
2004 Silverado 2500 Crew Cab 4x4, AMSOIL EA air filter, Granatelli MAF sensor, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, EGRUSA fender Flares and widow visors, extended stainless steel brake lines, firestone airbags w/onboard air compressor, Tuff Country trac bars, Pioneer Avic X940BT navigation, Accel backup camera.
1960 Land Rover Series II 88
2002 Nissan Altima (My Commuter)
NRA Life Member
Yukon Denali seat recline sensor location and adjustable pedal sensor location??
By Pikey in forum General Chevy & GM TechReplies: 3Last Post: 11-08-2012, 02:22 PM -
Engine code: P0121 TP sensor or APP sensor 1 problem
By mah2496 in forum GM Powertrain TechReplies: 0Last Post: 11-04-2011, 11:38 AM -
Cam sensor and Crank sensor problems?
By chevyhd24 in forum GM Powertrain TechReplies: 0Last Post: 09-11-2011, 08:56 AM -
Crank sensor out of time with cam sensor?
By revo18 in forum GM Powertrain TechReplies: 2Last Post: 07-30-2011, 10:02 AM -
P0154 code, O2 Sensor Circuit No Activity Detected Bank 2 Sensor 1
By bill426 in forum GM Powertrain TechReplies: 1Last Post: 12-07-2010, 06:47 AM
3 ton (6200lb) people hauler, Ultimate Transport V
2004 Chevy Silverado 2500
Bookmarks
