    Question vacume leak on throttle body
    I have a vacume leak on the bottom of my throttle body and im pretty sure its the seal where the butter fly shaft goes through it.My question is how difficult are they to replace and where can I a diagram of the tbi?Thanks Aaron
    While driving remember this rule of thumb,If another driver switches lanes infront of you cutting you off causing you to slam on the brakes to avoid a collision that they almost caused its your fault and you should be happy that they flip you the bird when you lay on the horn.
    throttle body is typically easy to replace. as far as a diagram is concerned I dont know but did you try to google it.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    I did find a diagram online of the throttle body thats used on my truck.I also gave a wrong description of the shaft where the bad orings are.Its the throttle shaft on the bottom of tb.Has anyone here ever replaced them?Am I going to have to get a complete rebuild kit for the TB?
    Mar 2013
    adirondacks,n.y.
    are you sure its shaft end seal?can you move shaft side to side?
    Yes Im sure I sprayed carb spray in the area of the shaft and my idle will go up.Its also making a whistling noise from the same area.
    Mar 2013
    adirondacks,n.y.
    try to spray lithium at that spot,carb spray just dries things out,what was symptom to go looking there?
  1. throttle body
    By R3dn3ck in forum General Chevy & GM Tech Questions
    Last Post: 05-03-2011, 08:37 PM
  2. tps and throttle body
    By vmax77009 in forum GM Powertrain
    Last Post: 03-09-2011, 04:32 PM
  3. Throttle Body
    By crane557 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-16-2010, 06:07 PM
  4. BBK Throttle Body
    By StevieBlues in forum Performance & Fuel
    Last Post: 04-16-2010, 09:06 PM
  5. Throttle body
    By andrejj in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 09-25-2006, 03:20 PM
