    Default Chevy Equinox Stereo Replacement
    Hey, I'm putting a new stereo in my friend's 05 equinox and it's different from my Toyota. There are two wiring harnesses going into the stereo instead of the just one on my car. Rather than just mess around until I figure it out, I was wondering if you could tell me what each of them are.
    Thanks!
    Jr. Engineer Rumpamuro's Avatar
    Apr 2007
    Mississauga, Ontario (Canada)
    every type of vehicle manufactuerer is different older toyotas used red as ground and black as power if you can figure that out. So first of all you need the wiring harness which you rbuddy has to decide if he wants to buy the cheap harness and keep the radio somewhere in the truck or spend more money and but the module, then from there its plug and play except for the switched power (ACC) you gotta tap into that wire, and run it somewhere where theres 12+ when the ignitions on and nothing when the keys off (fuse block ign2 usually works good).
    Quote Originally Posted by Rumpamuro View Post
    I've been trying to wire it to the fuse box by either tapping into the wires behind it or pulling out the fuse and sticking the wire in it's place, but no luck. What is the "ign2" or do you know which fuse I should try?
    Just buy to right harness. Does it have the bose system or not
    Apr 2007
    Quote Originally Posted by Clementi View Post
    the fuse ign2 theres usually 3 ign fuses on the newer gms, ign 1,2,3 but grab a test light and test te power first cus one of them is ground usually ign 2 is always power
    Thanks guys, I got the stereo working but two problems came up.
    1. Long story short, I need a new male wiring plug for the hazard lights/ turn signals. It's the brown plug with 8 wires coming out of it. Anyone know a site I could find one?
    2. The radio antenna wouldn't plug into the female plug on the Kenwood headunit, is there an adapter I need?
    thanks
  1. Chevy Silverado Stereo Replacement
    By Steve in forum Audio, Video & Gadget Tech
    Last Post: 02-24-2012, 12:44 PM
  2. Equinox stereo replacement / Ipod
    By chris636 in forum Chevy Equinox Forum (GMC Terrain)
    Last Post: 07-09-2011, 02:07 PM
  3. Equinox Console Replacement
    By dcrawford999 in forum Chevy Equinox Forum (GMC Terrain)
    Last Post: 01-25-2011, 09:39 AM
  4. Bowtie OEM stereo replacement
    By awparran in forum GM Parts Club
    Last Post: 01-18-2010, 01:04 PM
  5. Help with 2002 avalanche stereo replacement
    By davideg70 in forum Audio, Video & Gadget Tech
    Last Post: 12-27-2009, 08:22 PM
