Results 1 to 2 of 2
    Default Steering cluck recommendation needed.
    My '04 has the common steering clunk that I was to resolve. Found that the OEM part from Chevy is around $85.00 and there is an aftermarket part from Dorman available for around $50.00. Has anyone used the Dorman shaft? Does it eliminate the clunk? Good quality? Or should I stick with the OEM part?
    Opiewho
    2004 Silverado 2500HD W/T
    6.0L, RWD, Auto w/Towing Package
    Sr. Engineer
    Feb 2012
    Western Maryland/Wyoming
    Hi,
    If you do a search on this forum for a steering clunk fix, you will see how to repair your clunk without having to replace your shaft. I did it on my 04 and the clunk went away. Good luck.
  1. Pulling steering wheel, help needed. 2000 k2500
    By carmantx in forum General Chevy & GM Tech Questions
    Last: 02-06-2012, 11:47 AM
  2. Transmisson "Cluck"
    By waxsworth in forum GM Powertrain
    Last: 01-22-2012, 10:54 PM
  3. Part number needed for steering wheel
    By doug_scott in forum General Chevy & GM Tech Questions
    Last: 06-02-2010, 07:29 AM
  4. oil recommendation
    By ccmnova in forum GM Powertrain
    Last: 09-08-2009, 06:39 PM
  5. I need a tire recommendation
    By EdPDX in forum Wheels & Tires
    Last: 03-23-2008, 08:47 PM
