Results 1 to 10 of 14
    Default 2000 Suburban 2500 Tranny cooler reading hot when towing
    I have a 2000 Suburban 2500 4x4 with 180K miles. Last weeekend I was towing my boat which weights about 4000lb and the tranny cooler reading started getting pretty high, up to around 250 when going up some grades. When I got to the flats it went down a little but it stayed around 220 the entire time. My radiator gauge never moved from 190 which it never does. I did replace the tranny fluid about 25K ago so I am sure it is OK. I am just wondering if a Tranny cooler can go bad. I am sure the current cooler is stock and it does not look that big at all. What would be the best thing to look at first? This weekend it was only 82 degrees out and it was running hot so I am a little worried what will happen when the temps hit the 100's. Thanks in advance for any help.
    Quote Originally Posted by skongolf View Post
    As you mentioned, the Stock Factory Transmission Cooler is Small, I also was concerned about my Transmission Temps reaching 180, 190 and at times, Just over 200 Degrees, when Towing my Boat,
    IMO the Best Thing to do, is to go with a Larger Aftermarket Transmission Cooler....which is what I did.....so I Swapped out the Small Factory Trans. Cooler, and went with a Larger Cooler, Called a 40K Transmission Cooler, below is my Thread, regarding the removing of Factory Cooler and the installing of the 40K Cooler.
    Since installing the 40K Cooler, my Transmission Temps, when Towing my Boat have never gone over.....160 Degrees, this has been the Best Up-Grade I've done with helping to keep my Trans. Temps Down when Towing!!!.....but also one of the easiest Swaps I've done.
    http://www.gmtruckclub.com/forum/sho...mission-Cooler
    Thanks for the info. I skimmed your article, so did you just add this cooler along with the factory or just replace it? If I replace the factory one isnt it just a case of unbolting and removing the lines from the old one and install the new one? I thought I saw something where you cut the metal tranny line underneath. Unfortunately the pics from your install don't show up on my computer.
    Thanks
    Thanks
    I Removed the Factory Trans. Cooler all together, and then mounted and installed the 40K Cooler, here are the pictures of the......removing of the Factory Cooler and installed of the 40K Cooler, and the 3rd picture down, it shows how I mounted the Transmission Lines using the 2 Inverted Flair Fittings and Compression((Brass)Fitting onto the New Transmission Cooler......hopefully you will be able to See/View them??
    New True Cool 40K Installed With New EAD Upper and Lower Mounting Brackets
    Install of the Inverted Flair Fittings to both of the Transmission Hard-lines
    Install of the Compression(Brass)Fitting........to be able to Spin the Passenger Side Hard-Line 180 Degrees to Line-Up/Fit onto the Threads of the 40K Cooler
    Below are the Items/Parts used in the Install of the Transmission Cooler,
    True Cool 40K Transmission Cooler
    The 2 Inverted Flair Fittings and Compression((Brass)Fitting that were supplied in the EAD Kit,
    Mag-Hytec Transmission Pan
    http://www.mag-hytec.com/transmission.htm
    Seems fairly straightforward. My concern was having to cut into the hard line underneath that I saw in another video online.
    I had no problems with cutting the hard-line, to install the Compression Fitting, and have had no Issues/Problems with it since.....and it is "fairly straightforward".....also I'm guessing you were able to view the photo's above??....
    So I just went and checked and I do have the oem cooler. It is tiny! anyway, did you run two new cooler lines because on second look at your pics, they look different. Is there a description of how you did the lines anywhere? Hate to ask all the questions, but I will be doing this myself. Thanks
    The Only Mod(Cutting)of what I call the Passenger-Side Hard-line, and that was it....the factory hard-lines are the some ones, I didn't add any new hard-lines.
    This picture is of the Factory Cooler, notice where the Passenger-Side Hard-line is located and the Driver-Side Hard-line
    In this picture notice where the Pass-Side Hard-line is now, after the Install of the Compression(Brass)Fitting....I was to be able to Spin the Passenger Side Hard-Line 180 Degrees to Line-Up/Fit onto the Threads of the 40K Cooler
    and the Driver-Side Hard-Line is in the Same Spot, as it is in the picture above.
    In this photo, you can see the Compression Fitting, on the Passenger-Side Line,
    and then the Install of the Inverted Flair Fittings to both of the Transmission Hard-lines
    Hope this helps you out, regarding your Questions???
    Sure does. How hard was it to cut the line? Did it pull up enough to get a pipe cutter on it? Also did the mounting brackets come with the kit or did you have to make your own? I definately plan on doing this soon. Thanks again for all the answers.
    since you have had this vehicle for some time now and suddenly you notice that the tranny temp of 190 deg f which is normal expected now is in the 250 deg f range I would say that the transmission is slipping. now another reason this can occur is did you tow in 4th gear ? towing in 4th gear and not in tow mode will cause internal tranny temps to rise.
    installing a "huge" tranny cooler is a good upgrade , if you plan on towing in 100 deg f temps. it will also lower the engine temp. the only problem I found with installing a huge cooler is , the heater temp in cold weather takes much longer .
    I also noticed more power when towing in the hot weather.
    cutting the tubing lines you need a tubing cutter . do not use any saw . then if required you use the proper hoses or get more hard lines to complete the install using the compression fittings. do not over tighten these type fittings . the small seating part can crack. to secure these properly you tighten the nuts so they are snug then turn 3/4 of a turn . then take the fitting apart and check for proper seating position. on re-install tighten the fitting until you feel its not compressing those seats into the tubing any more .
  1. Tranny Cooler Line Leak
    By Z71silverado in forum GM Powertrain
    Last: 01-11-2012, 04:21 PM
  2. Tranny cooler
    By toughwaters in forum General Chevy & GM Tech Questions
    Last: 09-23-2010, 12:43 PM
  3. Steel braided tranny cooler lines.
    By Tiny1987 in forum GM Powertrain
    Last: 03-24-2010, 07:14 PM
  4. cooler line,tranny failure,
    By gardnergrendal in forum GM Powertrain
    Last: 06-12-2009, 08:44 PM
  5. tranny cooler
    By aerohead34 in forum Chevy Uplander & GM Minivan Forum
    Last: 08-28-2007, 05:41 PM
