Results 11 to 14 of 14
    Quote Originally Posted by skongolf View Post
    Sure does. How hard was it to cut the line? Did it pull up enough to get a pipe cutter on it? Also did the mounting brackets come with the kit or did you have to make your own? I definately plan on doing this soon. Thanks again for all the answers.
    As mentioned above by jcat, I used a Tube Cutter, which made a Clean Cut, and then installed the Compression fitting, no extra Hard-line hose is needed.....after Cutting the hard-line, I used a couple of Q-tips, at both ends of where the cut was made, to remove any small metal shavings.........regarding the mounting of the Cooler, it comes with Universal Mount Brackets, with these brackets, there is some fab work that needs to be done,
    Instead I when with EAD Performance "Mounting Bracket Kit" which is made for the 40K Cooler, and it comes with Upper and Lower Brackets and the Bolts and Hardware, the Brass Compression Fitting, and 2 Inverted Flair Fittings....the 40K bolts right-up to the mounting points, where the Factory Cooler was Mounted.......This Mounting Kit makes the Install A Snap!!! and When Done installing the 40K Cooler, it looks like a Factory Setup.
    I called the company that sells the Tranny cooler and asked them about the EAD Performance mounting kit and they didn't know what I was talking about. Where did you order the bracket from?
    The EAD Mounting Bracket Kit, to mount the 40K Transmission Cooler.....it does not come with Cooler,
    EAD Performance is the Company, that Makes and Sells, the mounting brackets for the 40K Transmission Cooler, it also Includes, the 2-inverted Flair Fittings and the Brass Compression Fitting.
    Skongolf,
    I just installed my new 40k trans cooler in our 2000 Chevy Suburban 2500 3/4 ton 2wd 10,000lb boat hauler w/200,000mi and saw my typical temps go down from 200* to 150*(in stop and go cross-town traffic no less). Didn't opt for the mounting bracket, merely used the hardware that came with the kit. Didn't opt for the Napa fittings either, just used the supplied hose and clamps. I'm so pleased with how easily it went in and how well it worked that I'll probably pull the grill and quickly do the hard fitting install.
    It was a breeze to install, fit behind the grill perfectly and is just what my trans needed. Best money I've spent in a long time.
    Thanks for the original post and followup "99Heartbeat". My transmission and I are infinitely grateful. Mike
  1. Tranny Cooler Line Leak
    By Z71silverado in forum GM Powertrain
    Last Post: 01-11-2012, 04:21 PM
  2. Tranny cooler
    By toughwaters in forum General Chevy & GM Tech Questions
    Last Post: 09-23-2010, 12:43 PM
  3. Steel braided tranny cooler lines.
    By Tiny1987 in forum GM Powertrain
    Last Post: 03-24-2010, 07:14 PM
  4. cooler line,tranny failure,
    By gardnergrendal in forum GM Powertrain
    Last Post: 06-12-2009, 08:44 PM
  5. tranny cooler
    By aerohead34 in forum Chevy Uplander & GM Minivan Forum
    Last Post: 08-28-2007, 05:41 PM
