    Default Traction Control / Performance
    Hey Ya'll,
    I have a 2010 Silverado, it's only a 2 wheel drive but I still take it off road; i have a jeep that i use to pull me out if i get stuck. My truck does pretty good in the mud and even when I turn the traction control off by holding the button down, I lose power when I go through the mud, even if I'm flooring it...
    Is this an engine performance issue? Or is there a way to completely disable the traction control?
    Any ideas??
    Thanks
    -Lo-
    Are you actually losing power, or just losing traction, and as a result, your engine isn't having to work as hard to turn the wheels.
    Seems like a normal condition, as you're describing it... When you say "power loss" can you be more specific? For example, are you having a hard time keeping both rear wheels engaged?
    -Skip
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
    My '09 works the same when in 2x4.
    Along with traction control, we also have stability control. The traction control can be turned off, the stability can not.
    I haven't looked for a fuse that could be pulled.
    Sr. Engineer nickgiacalone's Avatar
    Mar 2009
    Metro Detroit, MI
    On my 09 4x4 that I'm trading in tomorrow if you push and hold the TC button it will disable the Stabilitrac, you should get 2 noticed on the DIC right after one another....Upon immediately pushing the TC button it will say "Traction Control Disabled" keep holding the button for about 5 seconds and then you will get a message that says "Stabilitrac Disabled", at this point your TC and SC should BOTH be turned off. Well, at least that's how mine operates. I'll know tomorrow if the 2013s operate the same way.
    Hope this helps.
    -Nick
    2013 Silverado 1500 4x4 LT, Z71 Appearance Package, Vortec 5.3L AFM
    Victory Red, Ebony Cloth
    Custom pin striping, Bed Rail Protectors, GM Bed Liner, Husky Liner Floor Liners, Tint, Wade In-Channel Window Visors, Tractor Supply Black Low Profile Toolbox
    Quote Originally Posted by nickgiacalone View Post
    Hope this helps.
    Now that's good to know, thanks for the info.
    Mar 2009
    Metro Detroit, MI
    No problem! Hope it works!
    It does, had to go out and give it a try thanks.
  1. HELP! Traction Control
    By LB'07-Z in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-24-2011, 12:56 PM
  2. Traction control
    By Jhammer in forum GM Powertrain
    Last Post: 04-26-2011, 03:28 PM
  3. Traction control/ABS
    By alabamaxrebel in forum Lifted & Offroad Suspension
    Last Post: 03-23-2011, 02:58 PM
  4. Traction Control Active
    By brehemajac in forum The Coffee Shop ~ Chit Chat
    Last Post: 05-03-2010, 12:52 PM
  5. Traction control
    By Malek in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-12-2009, 04:21 PM
