    Default Trying to fix all the little broken bits ~ 2002 Suburban
    Instead of making a ton of new threads, I'll just keep them in here.
    2002 Burb Z71 5.3L
    1. Only one of my 3 a/c adapters in the front work. How do I try to fix them?
    2. Center console. Both a/c adapter and stereo controls don't work. I've been trying to find them locally in junkyards but all trucks in that year are totally stripped out. How can I trace the wire back to fix the cig lighter? I know there's no hope for the stereo unit except for a new one, anyone got a used one they don't need for sale?
    3. My ABS/Parking brake light keeps coming on either while driving or just start up. I've looked on this site and it might be a simple corroded wire.
    If you guys have any help on tricks LMK.
    What do you have in your garage?
    02 Burb Z71/97 Blazer LT
    Nuttin but bowties!!!!!!!!!!!!!
    Joshua T
    Have you checked fuses? I think the front and console outlets are seperate fuses. I don't have the stereo, but that might be fuses too.
    The ABS might be a dirty speed sensor in the front hub.
    Good luck,
    1999 Chevy K2500 Suburban 350
    Quote Originally Posted by joshuaT View Post
    2002 Burb Z71 5.3L
    1. Do they really have a/c outlets as in 120 volt a/c? Those are inverters supplied by the battery and it simply converts dc to ac power supply. It's possible the inverters are faulty or could be a missing 12 VDC supply.
    2. same as 1
    3. ABS/Brake lights are coming ON. I would start with cleaning the ground cables under the driver side frame rail, front engine to chassis ground. If that does not fix it, you have to clean all the wheel sesnors. If that still does not fix it, you have to pull the ABS module under the driver side frame rail and either send it out for repair or open it yourself and solder the cold solder joints on the relay pins that are cracked. Soldering the cracked joints fixed my ABS/Brakes issues coming on on the instrument panel.
    Good luck.
    2.
    1993 964
    1996 318TI
  1. Broken speedo on a 1999 2500 Suburban...help?
    By Stevodod in forum General Chevy & GM Tech Questions
    Last Post: 05-23-2012, 09:18 AM
  2. Broken hub
    By Landslide in forum General Chevy & GM Tech Questions
    Last Post: 03-26-2011, 09:07 AM
  3. being broken in
    By kingpin in forum Member Introductions
    Last Post: 10-18-2010, 10:54 PM
  4. 1994 GMC Suburban Broken Tailgate
    By xECKSx58 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-12-2010, 05:16 PM
  5. will 98 Suburban 4L60E fit in 2002 Suburban
    Last Post: 09-01-2008, 04:02 PM
