    Default 1985 short bed/ 96 suburban engine conversion
    Hi everyone, and excuse me for the redundant post, I am sure this has been covered before but I did not see my questions answered on the search function. I have a 85 GMC 4x4 short bed that has a tired 350 in front of a 4 speed auto tranny. I also have a 96 suburban that has a good 350 TBI. Suburban is nearly worthless after my wife really, REALLY whacked a deer.
    This gets me to thinking...if I can put the 96 engine in the 85 truck, I would have a sweet setup. For those of you who know the process, is it worth the hassle? Is it very straightforward to swap the engine and computer? Any wiring snafu's that will cause grief? I am fairly handy, and can certainly swap same engine for same engine with my skill level. I am unsure about this swap though, as it involves computers and wiring etc.....
    Is there a tech writeup on the process?
    Thanks for any guidance!
    I am sure that it could be done. It will be pretty involved, but you should be able to take all the harnesses and computer from the 96 and install it in the 85. It should be rather straight forward. My concerns would be the fuel pump, drive shaft, and if wheel speed sensors are needed to control the trans shift points. You may have to use an updated pump. You could probably use the trans from the 96 also. You may have to have some new mounts or brackets made. You would probably need a different length drive shaft also. I am sure that some others will come along with more details soon
    Dang it, the wheel sensors may be the deal killer. I was planning on using the tranny already in there as it was rebuilt a couple years ago.
    Quote Originally Posted by GunnerJ View Post
    if you are going to use the old trans you may be fine. Again, I am not sure if the speed sensors are even needed for the trans from the 96, I just thought that I would mention it as possibly being a complication. Someone that knows more will chime in soon!
  1. Replies: 2
    Last Post: 12-31-2012, 06:08 PM
  2. Nessie :: 1985 GMC Suburban
    By Reckin in forum Member Garages
    Last Post: 11-19-2012, 01:54 PM
  3. 350 engine replacement in my new 1985 GMC Sierra
    By mindiebee in forum GM Powertrain
    Last Post: 01-23-2012, 02:30 PM
  4. weight 1985 K10 suburban
    By gross in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-11-2010, 08:20 PM
  5. Parting Out: 1985 2WD Suburban
    By ocoinnigh in forum General Classifieds
    Last Post: 04-19-2008, 10:32 AM
