Results 1 to 10 of 12
    Default increased ground clearance
    If im upgrading from a 31" tire on a 17" wheel to a 33.5" tire on an 18" wheel about how much more ground clearance do you think i will get. i mean basic math would say about 2 inches but how true is that?
    Since you only provided overall diameter of the wheel and the tire (i.e. didn't provide tire width and profile information), I can't calculate what you're asking about, as there's not enough information. So, instead, I'll link you to the calculator I'd use and you can calc it, yourself, and answer your own question.
    http://www.miata.net/garage/tirecalc.html
    Best I can do given the info provided.
    this doesnt seem to give me any ground clearance information it just shows my spedo difference im going from 265/70/17 to 275/70/18
    Quote Originally Posted by chihawks35 View Post
    Try paying attention to the 'diameter' information for the old and new tire sizes. The delta between the two is the clearance you'll get. ..after considering/accounting for both wheel and tire information, which is what you were looking to do.
    i see what you're saying thanks
    goin from a 31 to a 33.5 should give you about an 1.25 inch gain in clearance. the center of both tires will mount to the hub in the same spot. so of the 2.5 inches of difference in size, half will be on top, and half will be on the bottom( which is what is going to add clearance)
  1. Ground Clearance
    By eag123 in forum Lifted & Offroad Suspension
    Last: 02-04-2012, 07:41 PM
  2. 99 2wd suburban with Sarona body kit ground clearance issue!!!Please help new member
    By 99Superban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-14-2011, 06:39 AM
  3. Increased Steering effort when parking
    By James1979 in forum General Chevy & GM Tech Questions
    Last: 09-12-2010, 12:17 PM
  4. Ground Clearance 2009 Sub
    By Room 055 in forum Lifted & Offroad Suspension
    Last: 03-29-2010, 10:33 AM
  5. Lift Kit / Increased Power
    By jrozalez in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-15-2010, 09:54 AM
