Results 1 to 10 of 27
    Default wont start no spark and i believe no fuel
    ok so i had to replace a broken fuel line behine the engine going down and i had to unplug to of the plugs on the distributor to make it easier.. i belive when i put it on i got the 2 mixed up it started drove back firing and runnning like **** but i drove it to work on my brake i was going to take it for a wash switched the wires started sounded better backed up went to go forward and died... so im not getting spark and now im not hearing the fuel pump kick on.. i replace the coil didnt work took the cap off the rotor spins.. i want to switch the realys around to see if that could be it and i have no idea what relay is what i search couldnt find i have a 96 gmc sonoma v6.. my realys are located on the engine bay firewall passenger side theres 4 of them.. its not in the glove box place... but if some one could tell me what realy is what grate if you have ideas on how to get it to work again even better
    Maybe a fuel pump?
    The first thing I would do is double check the firing order.Firing order is 1-6-5-4-3-2.Cylinders 1-3-5 are on the DRIVERS side front to back and 2-4-6 are on the PASSENGER side front to back. After you have corrected the order I would disconnect the battery to reset the computer and try to start it again. How strong is your battery?
    its all right in order now... and ive had the batt out twice for charging, but is there something that could of fried causing the fuel pump to not turn on and get no spark? and ive only tested spark in one cyl but i figured if ones not getting spark the other arnt either
    If I remember right, when I checked my fuel pump in my S10 blazer, I pulled out the fuel line and had someone turn it over and, while you hear it prime, if you don't see the fuel squirt out of the fuel line you pulled it may be your fuel pump.
    When checking for a spark in different cylinder heads, put a piece of metal inside the plug, put it close to the head, or around the motor, try to turn it over, and if you see an arc it's not that cylinder.
    Quote Originally Posted by DamnThatMexican View Post
    im not hearing it prime anymore... and when i tested for spark i just laid it on the valve cover saw no spark in the plug
  1. 1997 k1500 wont start-No spark
    By 97mud in forum GM Powertrain
    Last: 02-04-2013, 11:21 AM
  2. 1997 k1500 wont start-No spark
    By 97mud in forum Member Introductions
    Last: 01-29-2013, 01:03 PM
  3. Wont Start. Possible Fuel Pump??
    By DirtRider44 in forum General Chevy & GM Tech Questions
    Last: 03-19-2012, 04:16 PM
  4. Cranks, got fuel, got spark but wont start
    By bertram31 in forum Chevy C/K Truck Forum
    Last: 06-26-2011, 08:08 PM
  5. 96 Chevy 5.7 wont start, no spark, everything new! lol
    By mdm6713 in forum Performance & Fuel
    Last: 06-11-2010, 11:24 PM
