Results 1 to 10 of 15
    Default 2010 Silverado Leaking Transmisson Coolant Lines
    2010 Silverado 4.8 engine for the last few days I have noticed a "wet spot" about the size of a baseball under the front of the truck right behind the bumper. I first thought maybe I had splashed through a puddle or something but on the 2nd or 3rd time I raised the hood and the oil cooler lines for the transmission were wet and had a drip or two of fluid on them. The truck only has 73,000 miles and this seems a little premature to have these lines filing has anyone else had this issue?
    I would locate exactly where its leaking. could be coolant not dexronVI.
    White cloth, or paper, might help. The tranny fluid is red, the engine coolant is orange, or green.
    Unfortunately that is not uncommon, the lines on these vehicles are paper thin and rot out relatively quickly. If you drive in salt that is killer for them.
    Sr. Engineer nickgiacalone's Avatar
    Mar 2009
    Metro Detroit, MI
    Quote Originally Posted by Backroads View Post
    I don't want to be the bearer of bad news but, my 2009 that I just got rid of had a very slight leak right by the fitting going into the trans cooler. I live in Michigan so we have a ton of road salt. I noticed it at about 66,000 miles.
    -Nick
    2013 Silverado 1500 4x4 LT, Z71 Appearance Package, Vortec 5.3L AFM
    Victory Red, Ebony Cloth
    Custom pin striping, Bed Rail Protectors, GM Bed Liner, Husky Liner Floor Liners, Tint, Wade In-Channel Window Visors, Tractor Supply Black Low Profile Toolbox
    Quote Originally Posted by nickgiacalone View Post
    I'm down south in a largely salt-free area ... with a NBS truck that has 152k miles on it. While I got more mileage out of mine than others (probably due to lack of salt/brine), I just replaced my lines from the cooler, too.
    Mar 2009
    Metro Detroit, MI
    150k miles seems reasonable, but every NBS & NNBS truck that I know of with 65-80k miles has had trans cooler lines replaced. (Remember, I'm talking about people in MI). We have 14 GM pickups in out fleet at work (all 2002 or newer) and everyone of them has had the trans cooling lines replaced around 70k miles.
    GM needs to do something about this. I read somewhere people were having their local hydraulic shops make lines the replacement lines with the theory that the heavy duty rubber definitely can handle the pressure, plus it will not rot. As long as it doesnt rub I could see this being a pretty good idea.
    150k mi is reasonable. However, were I up north it'd have been a fraction of that, I'm sure...
    I started replaced all my hard lines with braided stainless, you can do it yourself and they're lifetime. I priced a set of PS lines at a local hydraulic line shop, they wanted several hundred dollars for two lines. Think not!! I don't even waste my time replacing the lines with factory hard lines, in my mind it's a temporary fix.
    I will say my mom's Aveo has in interesting design on it's transmission lines, they are teflon coated from the factory. Maybe GM is catching on, then again the car is made in Korea lol!!
    I pulled up a GM blog and it seems this happens quite often and 70k does not seem unusual what really rips me is the average GM repair cost seems to be $500 to $650 this is for transmission cooler lines I would hav expected this to be at least one half of that figure. Does anyone know the line pressure we are talking about? I believe I've seen older vehicles with 2 or 3 ply rubber lines and hose clamps on these joins. I f so is that possible here?
  1. Radiator Coolant Lines '99 Silverado 2500
    By bluebrick in forum Chevy Truck Talk & GM News
    Last: 01-05-2012, 12:21 AM
  2. leaking coolant
    By 250rman79 in forum General Chevy & GM Tech Questions
    Last: 06-01-2011, 11:49 PM
  3. Oil cooler lines Leaking!
    By kdr358 in forum Chevy C/K Truck Forum
    Last: 03-16-2011, 05:52 PM
  4. Engine Coolant leaking
    By Musclecargirl in forum GM Powertrain
    Last: 07-19-2008, 04:20 PM
  5. leaking coolant....BAD
    By 95CTburb19 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-12-2007, 05:28 PM
