Results 1 to 2 of 2
    Default Rear Speakers In Pillars on 2001 Siverado 1500 Base 2-Door Standard Cab
    I bought my truck with just the standard AM/FM Stereo radio. I'm in the process of replacing the right door speaker, no issues, I've found the cheap exact replacements through: MN Electronics.com. I removed the mounting bracket from the blown speaker. Behind the driver & passenger seats in the upper pillar, there is a grille for rear speakers on each side and the wiring is already present. The radio I have does not indicate in lettering a "fade" control. Though, the knob behind the tuning control does rotate and has a center position. My questions are, if I hook up a 4-ohm speaker (the speaker I removed from front door indicates it's a 4-ohm system) will there be power to the rear speaker at all? Also, what speaker size physical dimensions (OEM) fits in the rear pillars?
    Thank you
    I think the rear pillars were 4x6's not sure if the wires are powered. You could -just hook up any speaker to the wires and see if you have sound
    Last: 03-13-2013, 01:00 PM
  2. Replies: 0
    Last: 03-04-2013, 09:10 PM
    Last: 11-12-2012, 10:50 AM
  4. How to Remove rear speakers panels in a 2008 Silverado Standard Cab
    By PepperAnn in forum Member Introductions
    Last: 08-17-2012, 04:34 PM
  5. Speakers for rear pillars in a 96 Silverado
    By zzjakect in forum Audio, Video & Gadget Tech
    Last: 10-21-2010, 09:15 PM
