Results 1 to 2 of 2
    Default 2006 Colorado Check Engine
    Any known problems with cylinder 5 misfiring at 70 thousand km or so?What could be problem and any GM recall on it?
    I have not heard of that issue. But, I did a little research on it and found tons of info. It seems that the heads on those 5 cylinders have valve seats that are not hard enough and wear early. I am not saying that this is your issue. You need to rule out a coil pack , spark plug, and fuel delivery problem. After that I would suggest doing a cylinder leak down test on each cylinder, with the cylinder being tested being at Top Dead Center. From the info I found cylinder 5 and cylinder 2 are the cylinders with the known issues.
  1. 2006 5.3 check engine codes
    By ryan mecham in forum GM Powertrain
    Last: 10-23-2012, 09:54 PM
  2. 2006 5.3 check engine codes
    By ryan mecham in forum Member Introductions
    Last: 10-23-2012, 08:11 AM
  3. 2006 5.3 check engine codes
    By ryan mecham in forum General Chevy & GM Tech Questions
  4. Replies: 0
    Last: 06-01-2012, 03:10 PM
  5. 2006 tahoe check engine light
    By robsapache in forum Performance & Fuel
    Last: 10-13-2008, 02:07 PM
