Thread: H3 Clutch...
    Default H3 Clutch...
    Anyone have a 5 speed H3 that has to bleed the clutch once a year or more? Seems like the ol' H3 clutch needs bled every spring. You have to pump the clutch to build up pressure. Once I drain and refill then bleed I'm usually good for a least 6 months. Anyone else have this issue?
    "If it ain't one thing, it's a mother******g nother"
    I was always under the assumption if you have to do that often then the slave cylinder is bad.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    What would be bad about it you think? It doesn't lose fluid or anything.
    If its not leaking then something has failed and is allowing air into the system. the clutch runs off the brake system, so maybe even a bad brake booster or master cylinder. You are better off taking it to a reputable shop that understands clutches. They can be pretty tricky if you are not familiar with them.
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    since when has a clutch worked of the brake system? at most iv seen them share resivours (both use brake fluid) but nothing after that is shared. the clutch is its own system with its own master, slave, lines and pedal.
    All I meant was they share the same fluid and maybe the same reservoir (I shouldn't type that late at night, thought in head wasn't translated to fingers well), but something is wrong, you should never be having to consistently be bleeding air out of the clutch system, just the same as if you were constantly bleeding air out of your brakes
    It has it's own reservoir. When I have to bleed it once a year no air comes out. Some how it is getting contaminated, via heat or moisture. Anyway I just wanted to know if any other H3 owners had this issue. Thanks
    Quote Originally Posted by dedmon27 View Post
    I think that you have an issue somewhere. Slave cylinder possibly. You should not have to bleed it unless you open the system for some reason. It is a sealed system like your brakes. If I had to bleed my brakes every year I would be concerned.
