    Default New Shocks What Else?
    Ok so I asked a few weeks ago about new shocks and got some great advice. I went with the Monroe Reflex. I will be putting them on this comming weekend but i wanted to know as I am replacing the shock is there anything else i should look at to see if it needs to be replaced or worked on while im down there
    99 Silverado Ext Cab Z71 Third Door
    All stock for now
    Should just be the shock unless you find something that needs replacing.
    2005 Chevrolet Silverado 1500 LS V8 4.8L Ext Cab Standard bed. K&N Air Filter, and Flowmaster Series 40 Muffler. 2 12"in JL audio subs, 1500w amp
    2002 Ford F250 Lariat Powerstroke 7.3L Diesel Short Bed
    2004 Chevrolet Suburban LT
    check the frame for rust and corrosion. place a good mineral based rust proofing on the rusted metal . especially the cross member[s]
    Take a good look at all the rubber bushings and spacers. On a 99 they should be getting a little worn and weathered.
    Sway bar links Bushings and other bushings as said above..
    enkei nailed it...sway bar bushings and end links are cheap and easy to replace, and are probably getting pretty tired on a '99. I think you will like the Reflex, although a lot of times you can't really feel any diff until you have to make an emergency maneuver, after which you are glad you got new shocks.
    I would check all the fluids closely. Brake fluid should be a bit tan, or light grayish-brown...dark is not good, and you can change it yourself. Tranny should be a nice reddish/pink...anything looking toward reddish/brown means it's time to change, as does any burnt smell. You proably know that oil should not be black, unless you have a diesel (if you don't know when the last oil change was, and it looks dirty, change it...$25 is good insurance, and you will be good to go for 5K miles). Check the fluid level of the rear end and transfer case.
    Radiator should be a nice lime-green, or orange, depending on what is in there...in any even, it should have good color, not close to clear. I would also run a couple cans of chevron techron additive, or your other personal choice, through the fuel system just in case there is water, gunk, etc. Contrary to some beliefs, that does not constitute a "tune up in a can", but might prevent some problems, and it is cheap.
    If any of these are wrong, someone will chime in, I am sure.
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    York and Wilkes Barre, PA
    good luck with the shocks. I had they and regretted them right away. Love my blisten heavy duty's
    Objects in mirror are losing
  1. What shocks to go with?
    By Chewys Silverado in forum Lifted & Offroad Suspension
    Last: 10-05-2011, 10:20 PM
  2. shocks...
    By reggiecab2000 in forum Lifted & Offroad Suspension
    Last: 09-29-2011, 08:38 PM
  3. KYB shocks
    By kjb13 in forum Chevy C/K Truck Forum
    Last: 10-05-2010, 07:19 PM
  4. new shocks
    By coombia21 in forum Lifted & Offroad Suspension
    Last: 08-31-2009, 07:06 PM
  5. Used shocks
    By tigersdl65 in forum The Coffee Shop ~ Chit Chat
    Last: 08-09-2009, 12:44 PM
