Results 1 to 10 of 11
    Default Air condition not cycleing on,,
    98 GMC,, we put new compressor,, dryer,, office tube ,blew everything out,, and the compressor will not cycle on,, we change the low pressor switch,, on the dryer,,i think that what it is called. with one that we know works from another truck and still won't cycle on. we also put a jumper wire in and compressor comes on and air gets cold and works great,,But when ya plug the switch back in on dryer,,it won't kick compressor on. like i said we replaced the switch on dryer with one we know works and it still will not come on,, any ideas would be a big help,,thanks Rhonda
    any ideas at all,,thought someone would have a few ,,sigh
    I have no idea but if no one replays soon I would delete this post and re post here or maybe @Pikey could move it. I think it would be better there but I could also be wrong
    http://www.gmtruckclub.com/forum/for...vy-amp-GM-Tech
    Tim Walters (Curky)
    did you make sure to pull a vaccuum on the system before filling with freon (as well as check to see that it will maintain vaccuum. the compressor wont cycle if the freon is too low or too high.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Apr 2013
    East Central Iowa
    I would also make sure the low switch can activate the schrader valave in the drier.If it cant push in the switch won't close.
    yes we vacumed the system down,,,and it heald the vacum for 30 min,, the we filled with 134. we put a jumper wire in to start filling,, usually after first can we take jumper off and and plug it back in to the switch and it will go ahead and cycle,, but this one didn't,, we replaced the switch on dryer with one off our tahoe they are just alike and works fine on the tahoe ,, and it still will not cyce on and off, it is full of 134 and it gets cold and works great with the jumper wire in.. but it must cycle to keep from burning the compressor up..were just at a loss ,,don't know what to do to fix it,,,,thanks Rhonda
    sorry I couldnt help more. Hopefully someone elso can.
    David
    NRA Life Member
    I'm only going from memory on previous discussions about A/C units, but......
    Did you check both the high side and low side pressure switches? Fuse for the A/C?
    My two cents.
    csltrains96
    Myself, my beautiful wife
    3 - boys
    3 - minivans
    1 - 27 foot travel trailer
    Not enough family time!
    Have you checked the relay?? A bad relay will cause the compressor not to cycle.
    Ok Problem solved,,feel like a dummy,, we cleaned the prongs on the switch and spread them out a little,,and now it works like a charm,, thanks for all your ideas,,
  1. 96 K1500 Hard Start condition
    By Brently Harris in forum GM Powertrain
    Last Post: 02-24-2011, 02:22 AM
  2. Mint condition GMC Grill
    By FireRed in forum General Classifieds
    Last Post: 07-21-2010, 06:23 PM
  3. Overvoltage condition
    By K0WJ in forum GM Electrical Tech
    Last Post: 03-15-2010, 11:41 AM
  4. interesting condition
    By scgamer_99 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-04-2010, 12:46 AM
  5. strange brake condition
    By GM_Guy in forum Chevy Uplander & GM Minivan Forum
    Last Post: 06-10-2007, 05:28 PM
