Results 1 to 10 of 16
    Question Frame Repainting
    After 17+ years of dirty salty and wet New England winters much of the pint on my frame has warn away and in its place is surface rust. Later this spring I will be removing said rust and repainting the frame with flat black Rustoleum and a few layers of clear coat. I'm just wondering what the best method for this would be. I will try to remove all the parts I can to paint them as well.
    My method was going to be sand and brush off all the rust I can then tape/cover all I don't want black and first coat it with Rustoleum primer then a few coats of flat black and finish with 2-3 coats of clear. Anything else I should do?
    You're on the right track but I recommend a few more steps.
    • Remove as much as you can mechanically (i.e. sand, wire brush, dremel, drill).
    • Hit it with a chemical to get what you missed, as you can't/won't remove it all, mechanically. (I like Eastwood gel rust dissolver.)
    • You -could- go to primer next OR you could hit it with Eastwood fast etch -- which is yet another rust dissolver ... but this one leaves behind a protective coating that's also a prepped, paintable surface.
    • Prime it with several coats -- I like Eastwood's rust converter, as it guarantees you've not painted over rust.
    • Paint it -- top it with whatever you like. If you plan to keep the vehicle I'd suggest Eastwood's heavy duty anti-rust coating, as it can be had in clear (which is actually more of an amber) or black ... and leaves behind a self-healing, anti-rust film.
    If you choose to apply the anti-rust coating then it's good to maintain it every 1-2 years by cleaning under the truck and re-spraying it, since it will wear away (like anything, even you OEM paint). If you've got a pneumatic paint sprayer that's the way to go for your spraying needs, as you get much better volume control (i.e. you'll use less material) than with rattle cans.
    I did plan to sand and grind all the rust I could, but I didn't think about the remover. I'll look into that. I don't own a paint gun because my dad doesn't trust them because they jam/clog often. I see you have great dedication to Eastwood products I will check them out I was picking the Rustoleum because it is easy to use and convenient.
    @Conlan Rose,
    I wouldn't call it dedication. Rather, a number of folks on this very site have spoken well of Eastwood products, I tried them, myself, and had a similar experience. Here's a thread for reference: http://www.gmtruckclub.com/forum/sho...-removing-rust
  1. 76 K-frame
    By Shovelaynut in forum Chevy C/K Truck Forum
    Last: 07-01-2011, 07:23 PM
  2. diff in 2wd frame and 4x4 frame
    By 2wheelmudder in forum Lifted & Offroad Suspension
    Last: 05-19-2011, 01:32 AM
  3. repainting old rims
    By Cuda1500 in forum Lifted & Offroad Suspension
    Last: 08-06-2010, 08:39 PM
  4. repainting frame
    By coombia21 in forum Chevy Truck Accessories
    Last: 09-20-2009, 02:01 PM
  5. back rack repainting
    By bd1326 in forum General Chevy & GM Tech Questions
    Last: 05-17-2009, 12:34 PM
