    Default Anyone tried this? (VB-2 door treatment by cascade audio)
    http://www.cascadeaudio.com/car_nois...tallation.html
    Besides looking insanely amazing, apparently this has twice the damping ability of asphalt based sound deadeners, anyone ever heard of this, or tried it???
    its looking like it averages about $65.00 for 14 square feet (about $4.64/sq. ft.)
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    They do make a few things and everything I've used by Cascade has been very good..
    Spendy, but if it's 2x the damping then it's worth the price. However, this little bit of fine print is super important:
    "One of the last steps when properly treating the door is to apply small pieces of VB-5 gasketing foam to prevent squeaks, rattles and panel buzz."
    Based on that it looks like the stuff becomes rigid/hard ... hence the rattles/buzzes. This means it's great for what you see in the photos, but you can't layer it between contact points (like where metal meets metal; or metal meets plastic; or plastic meets plastic) in your dash or center console, etc to mitigate squeaks, rattles, and buzzes like you can an asphalt material.
    Another consideration is if you have to remove it, say, from the interior door panel so that you can replace, say, the power window motor ... it's probably a remove-it-all-and-replace-it-all type of scenario if you want to keep that look. That's another advantage for an asphalt-based product -- you can heat gun it, peel it back, do your work, and then put it back into position.
    My read on it is there's limited application ... but it's probably fantastic for its application if all instructions are followed ... until you have to do work past where it's positioned. I'd have used it on one layer of my doors (inner skin, as shown in photos) if I'd known about it ... and kept some around in case I had to work on the doors, later.
    i will be giving the company a call tomorrow to clarify on the uses and applications of this product, But i do definitely like the application on the door panel, and I would like to know as well, since it does not specify, whether it becomes rigid or stays pliable.
    I will update with results...
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    I bought/sold a 49 Packard last January that a previous owner had used this product on, I didnt have the car long enough to find many negative issues with the product. One thing I did note was that car sounded solid when closing the doors "thunk" and the interior was as quiet as a bank vault.
    I left the stereo blasting Z Z Top and you could barely hear it on the outsid with the doors closed.
    One negative issue I did find was if you didnt have some type of ventilation it got stuffy and warm inside quickly.
    Heat retention due to the improved insulation is definitely an issue when you sound deaden, be it with this stuff or Dynamat or Fatmat or what have you. Despite using a different product, I have the same thunk, the quiet interior, and can even crank music without it being noticed unless my windows are down. I even have some ZZ Top in the truck, too! Likewise it also gets warm inside, quickly, in the spring/summer. This is a GOOD THING in the winter, mind you, but not so much in the summer.
    99% UV reflective and 70% radiant heat reflective tint on all windows (including the windshield) really helps, though. It was much worse before I tinted...
    I normally dont tint windows on classic cars like the Packard, buyers like certain upgrades and will tolerate non period/factory upgrades but for some weird reason window tint on these classics really upsets them, and when Im trying to sell a $65,000 classic I dont want anything messing with my profit margin. Personally I'd love to tint the windows as dark as I can, it gives a good look to some of those old cars.
    So tint it ... and then take it off before you put it up for sale. Less filling, tastes great!
    Their normally up for sale within minutes after I buy them.
    My personal collection is holding steady at 12 classics and or hotrods for now since I dont have good storage for more than that. And Im to cheap to spend money on something I dont have to.
