Results 11 to 19 of 19
    Looks good so far. Can't wait to see it completed.
    UPDATE:
    1) bumper mounting plates made
    so summer school started earlier this week with some tough engineering classes, contrary to what I thought, I actually got some stuff done today with my shop teacher who was more than ecstatic to help me!
    heres a few hours work between my two summer classes...
    thankfully he had plenty of extra 1/2" steel laying around for me to use...
    so we popped it up in the bandsaw
Name:	IMG_2896 (640x480).jpg
    my two pieces, yes there are already some drilled holes in them, but oh well, doesnt affect the quality of them
Name:	IMG_2897 (480x640).jpg
    then the 4 holes for some 1/2" grade 8 bolts
Name:	IMG_2899 (480x640).jpg
Name:	IMG_2900 (640x480).jpg
    after cutting I test fitted and realized i needed to round the corners off
Name:	IMG_2901 (480x640).jpg
    here they are in place to cap off my frame horns.
Name:	IMG_2902 (640x480).jpg
    still need to tack weld the 4, 1/2" nuts on the back side of these plates, then weld these plates flush...
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    UPDATE:
    1) 3/8" steel for bolt on plates made
    2) nuts welded onto 1/2" mount plates
    3) mount plates welded onto end of frame horns
    4) grinded plate welds flush
    5) bolt on plate, bolted onto mount plates
Name:	IMG_2921 (640x480).jpg
Name:	IMG_2923 (640x480).jpg
Name:	IMG_2924 (480x640).jpg
Name:	IMG_2926 (640x480).jpg
Name:	IMG_2927 (640x480).jpg
Name:	IMG_2928 (640x480).jpg
Name:	IMG_2929 (640x480).jpg
Name:	IMG_2930 (640x480).jpg
Name:	IMG_2931 (640x480).jpg
    only welded three of the sides because my shop teacher said it was already more than enough.... though it may be true, i might finish the 4th edge for aesthetics...
Name:	IMG_2932 (640x480).jpg
Name:	IMG_2933 (640x480).jpg
Name:	IMG_2934 (640x480).jpg
    all that left now is to cut and weld the bumper support arms onto the 3/8" bolt on plates, and weld the bumper to the arms as well.....
    I know your building this for strength and all but are you gonna design in a sacraficial crush can or anything like that so in case of an accident you crush or bend something replaceable instead of a frame horn or rail?
  5. Likes mfleetwood liked this post
  6. #15
    I dont really have any kind of crush zone in mind... BUT, I am doing this in the bolt on method as shown, rather than straight welding my bumper to the frame for a reason similar to the one you stated. Welding the bumper to my frame would mean if I was to hit something hard, and something got bent, its only logical that something on my frame would be affected. instead I opted to cap off the frame, and make a 3/8" bolt on plate which will be connected to the bumper, and I will be able to remove the bumper IF NECESSARY, but perhaps the 4 1/2" bolts would break if I was to hit something that hard, which might constitute for a crush zone you are referring to...
  7. #16
    Looks good so far
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  8. #17
    Ok, just remember not to make the mistake of using the strongest hardware available, then you negate the crush zone (or in this case shear factor).
    Just a costly mistake I learned on an earlier prerunner bumper build.
  9. #18
    finished my bumper!!!
    only took a few months LOL
    but here she is...
    future plans will be to incorporate a skid plate and some sheet metal for gap filling then some light mounts...
Name:	IMG_3102 (640x480).jpg
Name:	IMG_3104 (640x480).jpg
Name:	IMG_3105 (640x480).jpg
  10. #19
    good job, glad you finally got it done.
  1. Rear bumper build thread.
    By Jimmeh in forum Photo & Video Gallery
    Last: 09-10-2012, 05:37 PM
  2. N Fab Prerunner Light Bar
    By marko54 in forum Chevy Truck Accessories
    Last: 04-18-2011, 10:51 AM
  3. Prerunner style front bumper
    By 98regcab in forum Chevy C/K Truck Forum
    Last: 12-25-2010, 04:02 PM
  4. Bumper or brush guard build plans
    By coombia21 in forum Chevy Truck Accessories
    Last: 02-16-2010, 03:31 PM
  5. SoCal Prerunner on red dirt
    By dgafguy619 in forum Lifted & Offroad Suspension
    Last: 01-03-2009, 10:18 PM
