    Default 2002 GMC Sonoma will not start
    Hi there my name is Mike I have a 2002 GMC Sonoma with a 2.2lt, 5sp. It just stopped running on Saturday, got it home and started checking things. It has spark, the injectors are firing, the fuel pump has 50lbs pressure and it won't start. I have tried ether and it still don't start. The motor will just turn over, but it sounds like a faint backfire in the exhaust. I checked the timing chain and it's not broke, tried another coil pack and still nothing, what I'm I missing????? This truck only has 78,000 miles, I've tried unplugging the MAP, TPS, O2, IAC, TEMP sensors and still nothing. Will be doing a Compression check tomorrow. Is there anything else you guy can think of or if any of you has had the same problem let me know. Thanks Mike
    Try checking your plug wire ends. Pull a plug and check the gap. Spark needs to be bright blue to run, yellow/orange spark won't lite. On the fuel side check for flow. Filter or pressure regulator may be plugged.
    Mine just got Fixed from same issue and it was the Ignition Control Module Very Cheap on ebay
    99 Gmc Sonoma SL 4.3L 4x4 Reg Cab Long Bed
  1. 01 gmc sonoma wont start/any help appreciated
    By jessica714 in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 07-31-2012, 11:45 PM
  2. Replies: 0
    Last Post: 05-27-2012, 07:40 AM
  3. 95 Sonoma - No Start Problem
    By mrharris32 in forum General Chevy & GM Tech Questions
    Last Post: 01-15-2012, 02:11 PM
  4. 92 Sonoma Sluggish start after sitting for a few hours.
    By Falcone in forum General Chevy & GM Tech Questions
    Last Post: 04-23-2009, 09:14 PM
