    Default GMC 2001 All time 4 WD jumping on sharp turns
    The truck is a GMC 2001 Sierra C3. All time 4 WD. After a longer than normal drive, making U turns or even turning into a parking spot, the front end looks and feels like it's going to jump off the road. It acts like the slip mechanism is locked not letting the tires rotate at different revolutions because of the turn. Kind of like a Detroit locker on your front end.
    I sure would appreciate an answer on this. Something tells me something bad is about to happen.
    Thanks...
    In the AWD trucks, the "slip" is in the transfer case. There is a clutch pack that "releases" when front drive is not required. Generally there is some clutch pressure at all times. This clutch pressure will send maybe 5% of the torque forward. It sounds like you are seeing more forward torque than you should.
    I would try changing the t-case fluid, new fluid will have the additives that lets the clutch pack slip.
    Yes try the replace the t-case fluid first check for any abnormal amounts of sludge coming out or in the pan after its drained, the replace with an approved fluid, with the auto t-cases you need a special fluid for the clutches.
    http://www.summitracing.com/parts/na...FQNlMgodOG0ACw
    I belive this is the fluid you want for that T-case
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  1. Truck stalling when making sharp turns or parking
    By brunetce in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-31-2012, 11:31 AM
  2. Newb jumping on in.....
    By Corso in forum Member Introductions
    Last Post: 12-31-2011, 07:38 PM
  3. jumping guages
    By jarhead74 in forum GM Electrical Tech
    Last Post: 04-03-2011, 05:40 PM
  4. A/C Belt jumping around
    By Crazeetxn in forum General Chevy & GM Tech Questions
    Last Post: 05-12-2010, 08:07 AM
  5. Bronco II jumping
    By Steve in forum Photo & Video Gallery
    Last Post: 11-11-2007, 08:12 PM
