    Default Unable to lower spare wheel
    Recently purchased a used 2001 Suburban.
    Attempting to lower the wheel, I was unable to get the end of the tool to 'grab' or 'seat', when inserted up the tube.
    I aimed a flashlight up the tube, and from as well as I can see, it appears as though there is something(metal) sheered off, at the end of the tube just above the wheel.
    Is there any "backup method" for getting the wheel down?
    Granted, I may be looking at replacing the wheel lowering mechanism, or at best extracting whatever some previous owner broke off up in there, but for now, I'd settle for just getting the wheel down.
    Any thoughts, ideas, or suggestions would be greatly appreciated!!
    -Gary
    well when they get stuck or break the only way i know of is to cut the cable, not ideal but it works. When you replace the unit make sure to lube it up and periodicaly use it to keep the gears and cable free and operating
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    I replace them frequently at work, the grime and dirt from the road gets inside them and makes them stick, as well as water getting in and causing rust. Replacement is your best option.
    Quote Originally Posted by gstadter View Post
    -Gary
    Are you sure you are using the correct end of the tool? Don't use the flat male end, use the square female end.
    1993 964
    1996 318TI
    Quote Originally Posted by bazar01 View Post
    There is a safety device that the tire hangs from. On my '03 burb it lowers about 6 inches, then you have to squeaze the mechanism to release teh safety hook. I took a pair of pliers and bent the tabs that hole the wheel. Dropped wheel onto ground, slid out and oiled mechanism so it works next time
    2003 Suburban 2500 LT, 6.0l Volant cai. 3.73 gear. Mobil 1 syn oil
  1. Spare wheel protection???
    By SurrealOne in forum Wheels & Tires
    Last Post: 07-05-2012, 10:53 AM
  2. 07 silverado spare wheel
    By silverado469 in forum Chevy Truck Accessories
    Last Post: 09-12-2010, 02:16 PM
  3. What's the trick to lower spare tire '05 Silverado?
    By Hwy St*r in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-16-2010, 01:59 PM
  4. spare wheel
    By silverado joe in forum Chevy Truck Accessories
    Last Post: 02-04-2010, 07:56 AM
  5. Tahoe Spare Wheel Hoist / Crank Problems
    By akita2791@yahoo.com in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 08-27-2006, 02:51 PM
